Crashing Moho 5.3 with Locked and Dynamic Constrained Bones
After taking a look at Ramon´s SeCrEt Crash test and thinking of the situation I had with the locking bone in a previous post I tried a simple test.
(I would post the Moho file, but Moho always crashed when I first tried to do anything).
A brief description:
Oval shape, 3 bones.
Bottom bone the Parent bone - locked.
Top two bones (not locked) given bone dynamics.
Go to time line, try to move any bone - CRASH! Moho has stopped to function, shuts down.
Tried it with various shapes, sizes, number of bones but always had one locked and children off that parent/root bone had bone dynamics on. Always crashed Moho.
I've tried Toontoonz recipe, but Moho didn't crash.
Moho 5.3, Mac OS X 10.3.9.
Here's my file, copy it, save it as "test.moho" and see if it crashes Moho or not:
application/x-vnd.lm_mohodoc
version 14
### Created in Moho version 5.3, � 1999-2005 Lost Marble
### Created: Thu Dec 8 23:43:45 2005
### static values
dimensions 320 240
frame_range 1 72
fps 24
back_color 234 234 234 255
noise_grain 0
allow_3d true
depth_sort false
distance_sort false
depth_of_field false 2 1 0.05
stereo_separation -1
extra_swf_frame false
soundtrack ""
### styles
### animated values
camera_track
keys 1
0 0 0.1 0.5 0 0 1.7321
camera_zoom
keys 1
0 0 0.1 0.5 1
camera_roll
keys 1
0 0 0.1 0.5 0
camera_pan_tilt
keys 1
0 0 0.1 0.5 0 0
### layers
layer_type 4
### generic layer values
name "Layer 2"
quality_flags 1022
origin 0 0
parent_bone -2
visible true
render_only false
edit_only false
scale_compensation true
rotate_to_follow false
face_camera false
masking 0
blend_mode 0
camera_immune false
dof_immune false
### transforms
translation
keys 1
0 0 0.1 0.5 0 0 0
scale
keys 1
0 0 0.1 0.5 1 1 1
rotation_x
keys 1
0 0 0.1 0.5 0
rotation_y
keys 1
0 0 0.1 0.5 0
rotation_z
keys 1
0 0 0.1 0.5 0
flip_h
keys 1
0 0 0.1 0.5 false
flip_v
keys 1
0 0 0.1 0.5 false
shear
keys 1
0 0 0.1 0.5 0 0 0
### layer effects
### bone layer values
expanded true
group_mask 0
depth_sort false
distance_sort false
skeleton
binding_mode 1
bones 4
"" -1 -1 1 -1 1 1 -1 1 false 0.44976 1 0 0
false -1.221731 1.221731
keys 1
0 0 0.1 0.5 false
2 2 1
keys 1
0 0 0.1 0.5 0.03307 -0.585334
keys 1
0 0 0.1 0.5 1.577927
keys 1
0 0 0.1 0.5 1
keys 1
0 0 0.1 0.5 false
keys 1
0 0 0.1 0.5 0 0
keys 1
0 0 0.1 0.5 0
"" 0 -1 1 -1 1 1 -1 1 false 0.433427 1 0 0
false -1.22173 1.22173
keys 1
0 0 0.1 0.5 true
2 2 1
keys 1
0 0 0.1 0.5 0.43984 0.000171
keys 2
0 0 0.1 0.5 0.015763
7 0 0.1 0.5 0.941961
keys 1
0 0 0.1 0.5 1
keys 1
0 0 0.1 0.5 false
keys 1
0 0 0.1 0.5 0 0
keys 1
0 0 0.1 0.5 0
"" -1 -1 1 -1 1 1 -1 1 false 0.0001 1 0 0
keys 1
0 0 0.1 0.5 false
2 2 1
keys 1
0 0 0.1 0.5 0.046298 -0.390223
keys 1
0 0 0.1 0.5 0
keys 1
0 0 0.1 0.5 1
keys 1
0 0 0.1 0.5 false
keys 1
0 0 0.1 0.5 0 0
keys 1
0 0 0.1 0.5 0
"" 0 -1 1 -1 1 1 -1 1 true 0.340718 1 0 0
keys 1
0 0 0.1 0.5 true
2 2 1
keys 1
0 0 0.1 0.5 0.879727 0.006955
keys 2
0 0 0.1 0.5 6.276058
7 0 0.1 0.5 5.097283
keys 1
0 0 0.1 0.5 1
keys 1
0 0 0.1 0.5 false
keys 1
0 0 0.1 0.5 0 0
keys 1
0 0 0.1 0.5 0
### sub-layers
layer_type 1
name "Layer 1"
quality_flags 1020
origin 0 0
parent_bone -1
visible true
render_only false
edit_only false
face_camera false
masking 0
blend_mode 0
camera_immune false
dof_immune false
### transforms
translation
keys 1
0 0 0.1 0.5 0 0 0
scale
keys 1
0 0 0.1 0.5 1 1 1
rotation_x
keys 1
0 0 0.1 0.5 0
rotation_y
keys 1
0 0 0.1 0.5 0
rotation_z
keys 1
0 0 0.1 0.5 0
flip_h
keys 1
0 0 0.1 0.5 false
flip_v
keys 1
0 0 0.1 0.5 false
shear
keys 1
0 0 0.1 0.5 0 0 0
### layer effects
### mesh layer values
noisy_shapes false
noisy_lines false
animated_noise false
noise_amp 0.033333
noise_scale 0.133333
extra_lines 0
gap_filling false
fill_texture ""
line_texture ""
mesh
points 4
keys 1
0 0 0.1 0.5 0.024802 0.631632
keys 1
0 0 0.1 0.5 -1
-2
false
1
0 0
keys 1
0 0 0.1 0.5 0.403451 0.024802
keys 1
0 0 0.1 0.5 -1
-2
false
1
0 1
keys 1
0 0 0.1 0.5 0.024802 -0.582027
keys 1
0 0 0.1 0.5 -1
-2
false
1
0 2
keys 1
0 0 0.1 0.5 -0.353846 0.024802
keys 1
0 0 0.1 0.5 -1
-2
false
1
0 3
curves 1
4 true
0 true
keys 1
0 0 0.1 0.5 0.244212
1 true
keys 1
0 0 0.1 0.5 0.627232
2 true
keys 1
3 true
keys 1
shapes 1
"" true true true true
4
0 0
0 1
0 2
0 3
false
keys 1
0 0 0.1 0.5 1 1 1 1
false 0.004167
false
keys 1
0 0 0.1 0.5 0 0 0 1
false
6.283185
0.25
true
-1
-1
-1
groups 0
Your example was not set up like I described above.
- Your top bone is not parented to any other bone.
- You bottom (parent/root) bone is not locked.
I had also selected in the bone dynamics for the top two bones Angle Constraints and Bone Dynamics.
Once I made those changes to your Moho 5.3 file, went in the time line, selected a bone to move then Moho crashed.
The top bone was parented to the bottom bone.
Indeed the bottom bone wasn't locked, because Moho will not allow me to do this; bone locking is unchecked immediately after I go to another frame. This is probably also the reason why I can't reproduce the crash. Bone locking doesn't seem to work at all, also in other situations (without bone dynamics).
So there's my bug:
Bone locking doesn't seem to work in Moho version 5.3
(Moho 5.3, Mac OS X 10.3.9)
So there's my bug:
The parenting in my 3 bone oval example (though I did not make it clear) was:
(top) bone (bone dynamics, not locked)
connected to
(middle) bone (bone dynamics, not locked)
connected to
(bottom) Parent bone (locked)
In that set up it crashes Moho.
Interesting you can´t get the one bone to lock.
Seems to be lots of interesting things in update 5.3.
connected to
connected to
- Lost Marble
The reason I tried this simple bones example was to see if it would crash Moho because I got the impression from LM´s response to Ramon`s bone crashing that it was due to out of the ordinary strangeness that was set up in that example.
Have not seen a warning to everyone from LM that bones in update 5.3 have a general serious problem and should be avoided until Moho is fixed.
I love to waste my time setting up bones animations and watching Moho crash and thinking it is my fault for doing something wrong and not the fault of the software....
- Lost Marble
