Crashing Moho 5.3 with Locked and Dynamic Constrained Bones
Toontoonz
Post by Toontoonz »
After taking a look at Ramon´s SeCrEt Crash test and thinking of the situation I had with the locking bone in a previous post I tried a simple test.
(I would post the Moho file, but Moho always crashed when I first tried to do anything).
A brief description:
Oval shape, 3 bones.
Bottom bone the Parent bone - locked.
Top two bones (not locked) given bone dynamics.
Go to time line, try to move any bone - CRASH! Moho has stopped to function, shuts down.
Tried it with various shapes, sizes, number of bones but always had one locked and children off that parent/root bone had bone dynamics on. Always crashed Moho.
ulrik
Post by ulrik »
I tried and made a similar setup, oval shape on vector layer inside bone layer, 3 bones, 1 locked 2 others with bone dynamics. When I try to manipulate a bone, moho crashes.
I'm using v.5.3 on mac osx 10.4.3
Rasheed
Post by Rasheed »
I've tried Toontoonz recipe, but Moho didn't crash.
Moho 5.3, Mac OS X 10.3.9.
Here's my file, copy it, save it as "test.moho" and see if it crashes Moho or not:
application/x-vnd.lm_mohodoc
version 14
### Created in Moho version 5.3, � 1999-2005 Lost Marble
### Created: Thu Dec  8 23:43:45 2005
### static values
dimensions 320 240
frame_range 1 72
fps 24
back_color 234 234 234 255
noise_grain 0
allow_3d true
depth_sort false
distance_sort false
depth_of_field false 2 1 0.05
stereo_separation -1
extra_swf_frame false
soundtrack ""
### styles
### animated values
camera_track
	keys 1
		0 0 0.1 0.5 0 0 1.7321
camera_zoom
	keys 1
		0 0 0.1 0.5 1
camera_roll
	keys 1
		0 0 0.1 0.5 0
camera_pan_tilt
	keys 1
		0 0 0.1 0.5 0 0
### layers
layer_type 4
	### generic layer values
	name "Layer 2"
	quality_flags 1022
	origin 0 0
	parent_bone -2
	visible true
	render_only false
	edit_only false
	scale_compensation true
	rotate_to_follow false
	face_camera false
	masking 0
	blend_mode 0
	camera_immune false
	dof_immune false
	### transforms
	translation
		keys 1
			0 0 0.1 0.5 0 0 0
	scale
		keys 1
			0 0 0.1 0.5 1 1 1
	rotation_x
		keys 1
			0 0 0.1 0.5 0
	rotation_y
		keys 1
			0 0 0.1 0.5 0
	rotation_z
		keys 1
			0 0 0.1 0.5 0
	flip_h
		keys 1
			0 0 0.1 0.5 false
	flip_v
		keys 1
			0 0 0.1 0.5 false
	shear
		keys 1
			0 0 0.1 0.5 0 0 0
	### layer effects
	### bone layer values
	expanded true
	group_mask 0
	depth_sort false
	distance_sort false
	skeleton
		binding_mode 1
		bones 4
			"" -1 -1 1 -1 1 1 -1 1 false 0.44976 1 0 0
			false -1.221731 1.221731
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
					0 0 0.1 0.5 0.03307 -0.585334
				keys 1
					0 0 0.1 0.5 1.577927
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
			"" 0 -1 1 -1 1 1 -1 1 false 0.433427 1 0 0
			false -1.22173 1.22173
				keys 1
					0 0 0.1 0.5 true
			2 2 1
				keys 1
					0 0 0.1 0.5 0.43984 0.000171
				keys 2
					0 0 0.1 0.5 0.015763
					7 0 0.1 0.5 0.941961
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
			"" -1 -1 1 -1 1 1 -1 1 false 0.0001 1 0 0
				keys 1
					0 0 0.1 0.5 false
			2 2 1
				keys 1
					0 0 0.1 0.5 0.046298 -0.390223
				keys 1
					0 0 0.1 0.5 0
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
			"" 0 -1 1 -1 1 1 -1 1 true 0.340718 1 0 0
				keys 1
					0 0 0.1 0.5 true
			2 2 1
				keys 1
					0 0 0.1 0.5 0.879727 0.006955
				keys 2
					0 0 0.1 0.5 6.276058
					7 0 0.1 0.5 5.097283
				keys 1
					0 0 0.1 0.5 1
				keys 1
					0 0 0.1 0.5 false
				keys 1
					0 0 0.1 0.5 0 0
				keys 1
					0 0 0.1 0.5 0
	### sub-layers
	layer_type 1
		name "Layer 1"
		quality_flags 1020
		origin 0 0
		parent_bone -1
		visible true
		render_only false
		edit_only false
		face_camera false
		masking 0
		blend_mode 0
		camera_immune false
		dof_immune false
		### transforms
		translation
			keys 1
				0 0 0.1 0.5 0 0 0
		scale
			keys 1
				0 0 0.1 0.5 1 1 1
		rotation_x
			keys 1
				0 0 0.1 0.5 0
		rotation_y
			keys 1
				0 0 0.1 0.5 0
		rotation_z
			keys 1
				0 0 0.1 0.5 0
		flip_h
			keys 1
				0 0 0.1 0.5 false
		flip_v
			keys 1
				0 0 0.1 0.5 false
		shear
			keys 1
				0 0 0.1 0.5 0 0 0
		### layer effects
		### mesh layer values
		noisy_shapes false
		noisy_lines false
		animated_noise false
		noise_amp 0.033333
		noise_scale 0.133333
		extra_lines 0
		gap_filling false
		fill_texture ""
		line_texture ""
		mesh
			points 4
					keys 1
						0 0 0.1 0.5 0.024802 0.631632
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 0
					keys 1
						0 0 0.1 0.5 0.403451 0.024802
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 1
					keys 1
						0 0 0.1 0.5 0.024802 -0.582027
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 2
					keys 1
						0 0 0.1 0.5 -0.353846 0.024802
					keys 1
						0 0 0.1 0.5 -1
				-2
				false
				1
					0 3
			curves 1
				4 true
					0 true
						keys 1
							0 0 0.1 0.5 0.244212
					1 true
						keys 1
							0 0 0.1 0.5 0.627232
					2 true
						keys 1
					3 true
						keys 1
			shapes 1
				"" true true true true
					4
						0 0
						0 1
						0 2
						0 3
						false
							keys 1
								0 0 0.1 0.5 1 1 1 1
						false 0.004167
						false
							keys 1
								0 0 0.1 0.5 0 0 0 1
						false
						6.283185
						0.25
						true
						-1
						-1
						-1
			groups 0
Toontoonz
Post by Toontoonz »
Your example was not set up like I described above.
- Your top bone is not parented to any other bone.
- You bottom (parent/root) bone is not locked.
I had also selected in the bone dynamics for the top two bones Angle Constraints and Bone Dynamics.
Once I made those changes to your Moho 5.3 file, went in the time line, selected a bone to move then Moho crashed.
Rasheed
Post by Rasheed »
The top bone was parented to the bottom bone.
Indeed the bottom bone wasn't locked, because Moho will not allow me to do this; bone locking is unchecked immediately after I go to another frame. This is probably also the reason why I can't reproduce the crash. Bone locking doesn't seem to work at all, also in other situations (without bone dynamics).
So there's my bug:
Bone locking doesn't seem to work in Moho version 5.3
(Moho 5.3, Mac OS X 10.3.9)
Toontoonz
Post by Toontoonz »
The parenting in my 3 bone oval example (though I did not make it clear) was:
(top) bone (bone dynamics, not locked)
connected to
(middle) bone (bone dynamics, not locked)
connected to
(bottom) Parent bone (locked)
In that set up it crashes Moho.
Interesting you can´t get the one bone to lock.
Seems to be lots of interesting things in update 5.3.
Rasheed
Post by Rasheed »
I'm seriously considering to go back to an earlier version until a bug fix is released.
Lost Marble
Post by Lost Marble »
This is the same problem as a bone-related crash that Ramon reported in another thread. The fix is coming soon.
Crashing bones --- ee-e-euh-uuhhh...
Toontoonz
Post by Toontoonz »
The reason I tried this simple bones example was to see if it would crash Moho because I got the impression from LM´s response to Ramon`s bone crashing that it was due to out of the ordinary strangeness that was set up in that example.
Have not seen a warning to everyone from LM that bones in update 5.3 have a general serious problem and should be avoided until Moho is fixed.
I love to waste my time setting up bones animations and watching Moho crash and thinking it is my fault for doing something wrong and not the fault of the software....
Lost Marble
If you're experiencing this problem, please re-download Moho to get a fix. After reinstalling, check that the version number in Moho's about box is 5.3.1.
