Octopus Tentacles
DK
Octopus Tentacles
Post by DK »
Can anyone suggest a way to animate a nice smooth arc like an octopus tentacle in AS WITHOUT using bones? I find bones put too many kinks in the arcs when animated.
Cheers
D.K
Oh? I don't think so. The trick seems to be to have many points and many bones, and adjusting the bone strength correctly. For stuff like this I use the grid when creating the bones.
http://www.slowtiger.de/examples/tentacle.mov
http://www.slowtiger.de/examples/tentacle.anme.zip
I was lazy and created just 1 shape, with the known effect in overlap.
Tip: Create 1 rectangle with the grid, then add points along the sides. Then switch off the grid, use G to select just 1 row of points, use R to rotate it just a bit. Repeat with other side: perfect tentacle.
DK
Post by DK »
Would'nt it be great to be able to use a line and pont motion like you can bones? You could then use the curvature tool to tweek things.
Cheers
D.K
Didn't selgin show how this could be done not so long ago?
jahnocli wrote:Didn't selgin show how this could be done not so long ago?
Maybe this one?
viewtopic.php?t=17713
