DV Tween Machine v1.0
Re: Tween machine (DONE)
I took the liberty and made some adjustments!
All my ideas mentioned above are implemented and the slider has been separated from Alexandra Evseeva's Keys Tool for clarity's sake.
While scrubbing the timeline the slider now estimates a percentage so you get a sense of a starting point before you start adjusting the tween.
While dragging the slider the new pose is now previewed in the viewport. When you let go of the mouse it sets a key. The preview makes a huge difference because it's now less trial and error.
You can still set the percentage by typing it in the field, just hit 'enter' instead of the 'OK' button.
Here's the link:
Here's the link:
- davoodice2
nice work.great!Lukas wrote: ↑Tue Sep 28, 2021 5:04 am I took the liberty and made some adjustments!
Here's the link:
I think ok button must exist. some time we want to just click ok because percentage in fine for many situations. And a option to disable live preview should be a good thing
I added this to first post.
- davoodice2
Re: DV Tween Machine v1.0
New Edition Released.
Thanks for this mod! I'm liking the expanded options a lot, like only timeline visible layers, use step intervals, etc. But the "only selected bones" option doesn't seem to be working, and prevents child layers from being animated even if the "include child layers" and or the "time visible child layers only" are enabled.
I often use this script in animation. Very comfortably. Just wanted to say thank you!
- davoodice2
thanks all. I don't know if this works on references layers for you.
I tried using this other version but I get the error "DV_TweenMachine.lua:646: attempt to perform arithmetic on local 'valN' (a string value)".davoodice2 wrote: ↑Sat Sep 04, 2021 1:10 am This is my previous Tween machine script with some improvements.
DOWNLOAD
https://www.mediafire.com/file/dlv71283 ... 1.rar/file
- lucasfranca
I need to learn to use this script. Does anyone have a tutorial?
https://youtube.com/animai2D
Yep. Not mine. The script is one of my favourites. Hoping for a built in. One can dream.lucasfranca wrote: ↑Wed Jun 01, 2022 10:43 am I need to learn to use this script. Does anyone have a tutorial?
Noob_krusher3000
Did you find a solution for that error? I'm getting the same thing. It worked twice, but then decided to dish out error messages every time I attempted to create an extreme. Please Help...Daxel wrote: ↑Wed Jun 01, 2022 8:51 amI tried using this other version but I get the error "DV_TweenMachine.lua:646: attempt to perform arithmetic on local 'valN' (a string value)".davoodice2 wrote: ↑Sat Sep 04, 2021 1:10 am This is my previous Tween machine script with some improvements.
DOWNLOAD
Nope, sadly I didn't manage to solve the issue or get any info about it.Noob_krusher3000 wrote: ↑Wed Jan 11, 2023 4:02 pm
- davoodice2
you have to have key before and after of current frame.Noob_krusher3000 wrote: ↑Wed Jan 11, 2023 4:02 pmDid you find a solution for that error? I'm getting the same thing. It worked twice, but then decided to dish out error messages every time I attempted to create an extreme. Please Help...Daxel wrote: ↑Wed Jun 01, 2022 8:51 amI tried using this other version but I get the error "DV_TweenMachine.lua:646: attempt to perform arithmetic on local 'valN' (a string value)".davoodice2 wrote: ↑Sat Sep 04, 2021 1:10 am This is my previous Tween machine script with some improvements.
DOWNLOAD
I already knew that but I still downloaded the latest version from mohoscripts.com to try it and right now I'm not getting that error for some reason. I still can't make the "only selected bones" option work. Every bone is affected by it. Does that option work on your computer?davoodice2 wrote: ↑Fri Jan 13, 2023 11:44 am
Now I tried lukas version and it's giving me this error: LK_TweenMachine.lua:557: attempt to perform aritmetic on local 'valN' (a boolean value) and it doesn't work.
Noob_krusher3000
That's not good. The thing is, it's given me errors in different projects on different devices, but even after giving me an error, it still performed fine... This time, on a fresh installation it finally decides to fall apart. I love this script, I hope it can be fixed.
- lucasfranca
Please, I was curious to know the rest of this image, it seems to me a very beautiful production. Can you share?
