DV Tween Machine v1.0
Lukas
Re: Tween machine (DONE)
Post by Lukas »
I took the liberty and made some adjustments!
All my ideas mentioned above are implemented and the slider has been separated from Alexandra Evseeva's Keys Tool for clarity's sake.
While scrubbing the timeline the slider now estimates a percentage so you get a sense of a starting point before you start adjusting the tween.
While dragging the slider the new pose is now previewed in the viewport. When you let go of the mouse it sets a key. The preview makes a huge difference because it's now less trial and error.
You can still set the percentage by typing it in the field, just hit 'enter' instead of the 'OK' button.
Here's the link:
davoodice2
Post by davoodice2 »
Lukas wrote: Tue Sep 28, 2021 1:04 pm I took the liberty and made some adjustments!
Here's the link:
nice work.great!
I think ok button must exist. some time we want to just click ok because percentage in fine for many situations. And a option to disable live preview should be a good thing
I added this to first post.
davoodice2
Re: DV Tween Machine v1.0
New Edition Released.
Here's the link:
Thanks for this mod! I'm liking the expanded options a lot, like only timeline visible layers, use step intervals, etc. But the "only selected bones" option doesn't seem to be working, and prevents child layers from being animated even if the "include child layers" and or the "time visible child layers only" are enabled.
KuzKuz
Post by KuzKuz »
I often use this script in animation. Very comfortably. Just wanted to say thank you!
davoodice2
thanks all. I don't know if this works on references layers for you.
davoodice2 wrote: Sat Sep 04, 2021 9:10 am This is my previous Tween machine script with some improvements.
DOWNLOAD
https://www.mediafire.com/file/dlv71283 ... 1.rar/file
I tried using this other version but I get the error "DV_TweenMachine.lua:646: attempt to perform arithmetic on local 'valN' (a string value)".
lucasfranca
Post by lucasfranca »
I need to learn to use this script. Does anyone have a tutorial?
https://youtube.com/animai2D
lucasfranca wrote: Wed Jun 01, 2022 6:43 pm I need to learn to use this script. Does anyone have a tutorial?
Yep. Not mine. The script is one of my favourites. Hoping for a built in. One can dream.
Noob_krusher3000
Post by Noob_krusher3000 »
Daxel wrote: Wed Jun 01, 2022 4:51 pm
DOWNLOAD
Did you find a solution for that error? I'm getting the same thing. It worked twice, but then decided to dish out error messages every time I attempted to create an extreme. Please Help...
Noob_krusher3000 wrote: Thu Jan 12, 2023 1:02 am
Nope, sadly I didn't manage to solve the issue or get any info about it.
davoodice2
DOWNLOAD
you have to have key before and after of current frame.
davoodice2 wrote: Fri Jan 13, 2023 8:44 pm
I already knew that but I still downloaded the latest version from mohoscripts.com to try it and right now I'm not getting that error for some reason. I still can't make the "only selected bones" option work. Every bone is affected by it. Does that option work on your computer?
Now I tried lukas version and it's giving me this error: LK_TweenMachine.lua:557: attempt to perform aritmetic on local 'valN' (a boolean value) and it doesn't work.
Noob_krusher3000
That's not good. The thing is, it's given me errors in different projects on different devices, but even after giving me an error, it still performed fine... This time, on a fresh installation it finally decides to fall apart. I love this script, I hope it can be fixed.
lucasfranca
Please, I was curious to know the rest of this image, it seems to me a very beautiful production. Can you share?
