Hi everyone.
I want to find a script to move in timeline to frame Zero.
I know there is a mynd tools plugin that copies the frames without going to frame zero.
The one I need is a button that transports me to frame zero and it can work in 13.5. I think there was one before, but I can't find it.
Thank you
Script to move in timeline to frame Zero
- negroclarito
Re: Script to move in timeline to frame Zero
You can use Design Mode for that. The shortcut is Shift-Control D. This sends you to frame 0. Use the shortcut again and it sends you back to the animation frame you came from.
In MQC, there's a Design Mode button than can be click-toggled with a pen or mouse.
Ooo, I like this shortcut. Thanks for posting.
Gems like this is why I browse the forum.
I think that you can alternatively use control + space to switch to design mode.
I thought I would knock up a simple Go to frame Zero script for those tablet warriors who don't like keyboards.negroclarito wrote: ↑Sun Jun 27, 2021 12:33 am ..
ZIP Package (with Icon): https://github.com/SimplSam/moho-go-zer ... o_zero.zip
-- Tool to emulate Design mode keyboard toggle
-- Go to frame 0 and back
ScriptName = "SS_GoZero"
-- General information about this script #510628
SS_GoZero = {}
function SS_GoZero:Name()
return 'Go to Frame Zero'
end
function SS_GoZero:Version()
return '1.0'
end
function SS_GoZero:UILabel()
end
function SS_GoZero:Creator()
return 'SimplSam'
end
function SS_GoZero:Description()
return "Toggle timeline to Frame 0 (Design mode) and back"
end
-- Is Relevant / Is Enabled
function SS_GoZero:IsRelevant(moho)
return true
end
function SS_GoZero:IsEnabled(moho)
return true
end
-- The guts of this script
function SS_GoZero:Run(moho)
if (moho.frame ~= 0) then
SS_GoZero.lastFrame = moho.frame
moho:SetCurFrame(0)
else
if (SS_GoZero.lastFrame) then
moho:SetCurFrame(SS_GoZero.lastFrame)
end
end
end
- negroclarito
Yes... It's working. PERFECT!!!. This is what I need. This can save a lot of time.Greenlaw wrote: ↑Sun Jun 27, 2021 12:57 am You can use Design Mode for that. The shortcut is Shift-Control D. This sends you to frame 0. Use the shortcut again and it sends you back to the animation frame you came from.
Thank you
- negroclarito
The shortcut Greenlaw told me is working perfect. I also want to try also this script.SimplSam wrote: ↑Sun Jun 27, 2021 8:51 pmI thought I would knock up a simple Go to frame Zero script for those tablet warriors who don't like keyboards.negroclarito wrote: ↑Sun Jun 27, 2021 12:33 am ..
-- ************************************************** -- Tool to emulate Design mode keyboard toggle -- Go to frame 0 and back -- ************************************************** ScriptName = "SS_GoZero" -- ************************************************** -- General information about this script #510628 -- ************************************************** SS_GoZero = {} function SS_GoZero:Name() return 'Go to Frame Zero' end function SS_GoZero:Version() return '1.0' end function SS_GoZero:UILabel() return 'Go to Frame Zero' end function SS_GoZero:Creator() return 'SimplSam' end function SS_GoZero:Description() return "Toggle timeline to Frame 0 (Design mode) and back" end -- ************************************************** -- Is Relevant / Is Enabled -- ************************************************** function SS_GoZero:IsRelevant(moho) return true end function SS_GoZero:IsEnabled(moho) return true end -- ************************************************** -- The guts of this script -- ************************************************** function SS_GoZero:Run(moho) if (moho.frame ~= 0) then SS_GoZero.lastFrame = moho.frame moho:SetCurFrame(0) else if (SS_GoZero.lastFrame) then moho:SetCurFrame(SS_GoZero.lastFrame) end end end
Thank you
