Script to move in timeline to frame Zero
negroclarito
Post by negroclarito »
Hi everyone.
I want to find a script to move in timeline to frame Zero.
I know there is a mynd tools plugin that copies the frames without going to frame zero.
The one I need is a button that transports me to frame zero and it can work in 13.5. I think there was one before, but I can't find it.
Thank you
Re: Script to move in timeline to frame Zero
You can use Design Mode for that. The shortcut is Shift-Control D. This sends you to frame 0. Use the shortcut again and it sends you back to the animation frame you came from.
In MQC, there's a Design Mode button than can be click-toggled with a pen or mouse.
Hoptoad
Post by Hoptoad »
Ooo, I like this shortcut. Thanks for posting.
Gems like this is why I browse the forum.
I think that you can alternatively use control + space to switch to design mode.
SimplSam
Post by SimplSam »
negroclarito wrote: ↑Sun Jun 27, 2021 12:33 am ..
I thought I would knock up a simple Go to frame Zero script for those tablet warriors who don't like keyboards.
ZIP Package (with Icon): https://github.com/SimplSam/moho-go-zer ... o_zero.zip
-- Tool to emulate Design mode keyboard toggle
-- Go to frame 0 and back
ScriptName = "SS_GoZero"
-- General information about this script #510628
SS_GoZero = {}
function SS_GoZero:Name()
    return 'Go to Frame Zero'
end
function SS_GoZero:Version()
    return '1.0'
end
function SS_GoZero:UILabel()
end
function SS_GoZero:Creator()
    return 'SimplSam'
end
function SS_GoZero:Description()
    return "Toggle timeline to Frame 0 (Design mode) and back"
end
-- Is Relevant / Is Enabled
function SS_GoZero:IsRelevant(moho)
    return true
end
function SS_GoZero:IsEnabled(moho)
    return true
end
-- The guts of this script
function SS_GoZero:Run(moho)
    if (moho.frame ~= 0) then
        SS_GoZero.lastFrame = moho.frame
        moho:SetCurFrame(0)
    else
        if (SS_GoZero.lastFrame) then
            moho:SetCurFrame(SS_GoZero.lastFrame)
        end
    end
end
negroclarito
Greenlaw wrote: ↑Sun Jun 27, 2021 12:57 am You can use Design Mode for that. The shortcut is Shift-Control D. This sends you to frame 0. Use the shortcut again and it sends you back to the animation frame you came from.
Yes... It's working. PERFECT!!!. This is what I need. This can save a lot of time.
Thank you :D
negroclarito
SimplSam wrote: ↑Sun Jun 27, 2021 8:51 pm
SS_GoZero = {}
end
    return '1.0'
end
end
    return 'SimplSam'
end
end
    return true
end
    return true
end
        moho:SetCurFrame(0)
    else
        end
    end
end
The shortcut Greenlaw told me is working perfect. I also want to try also this script.
Thank you :D
