Creating 2 joined points with different curvature
jhbmw007
Post by jhbmw007 »
Here's a quick tutorial that might be helpful to newbies. Sometimes when creating a curve that shares a point with another curve, you might become frustrated because your new curve might not look the way you want it to, due to the shared point's existing curvature setting. Here's a remedy:
We'll use a simple circle as example:
Now let's say you want to create a curve going through the middle of the circle, using the exisiting 2 points on the sides of the circle. Let's see what happens when we do that:
That curve's not the way we want it. We want a "crescent" curve- which would require that the 2 end points be set to "peak". Okay, let's set them to "peak":
Whoa! That really screwed up our circle didn't it? Let's undo that, and I'll show you how to get the crescent curve we want: Add 2 points to the new curve, right next to the "end" points:
That may look "good enough" now, but when you render it you'll notice it's not a perfect crescent. "Peak" the two new points you just created:
Now, drag each point over to the point next to it (circle edges) and bind these points together using spacebar:
The you'll want to select the middle point and set it's curvature to the maximum amount of "curve":
And there you have it- a perfect circle with a perfect crescent curve going through it. You could now create seperate fills on each halve of the circle. This was a very simple example; it can be used in many situations where you want to use shared points with different curavature settings.
You can save a couple of steps but this would only work if the shape isn't already created:
Draw the line before connecting it and peak the end points. Now connect to the circle with Auto-weld checked.
Another trick, if you use Fazek's curve tool you can change the curve of the end points of the cross section without effecting the circle's curve. This has been saving me a ton of work.
jhbmw007
Post by jhbmw007 »
Man- I learn something new about this program every day. I just figured out Fazek's curve tool- I never knew it could do that!
