Spinners undo
Hamedss
Spinners undo
Post by Hamedss »
If you change values of spinner any change of spinner in numbers counts in undo levels.
Please stop this nightmare
davoodice2
Re: Spinners undo
Post by davoodice2 »
agree.
Also opacity value can go higher than 100 and lower than 0. :D
Re: Spinners undo
I like scrubbing in the values, but I agree; the un-do issue can get annoying when I need to return to a state before I started scrubbing. I wish 1 'scrub' event would be counted as a single un-do.
doodleDaze
Re: Spinners undo
Post by doodleDaze »
A little work around i do (mostly in design stage with curve values but it could work with just about anything keyable) is go forward frames (the keys become undos) once i find the value i want then copy the key to frame zero then delete the keys. (I use 14.1 so i don't know if there has been any changes in .2 or .3)
Re: Spinners undo
That's clever...I'll give it a try! Thanks for sharing the tip. :)
