[Request] Broken line script
8BitHobo
Post by 8BitHobo »
I'm working on a project, and the backgrounds are all made in this stylized way in Affinity where you can make your lines have dashes. You can specify the gap and the length of the line to give a fairly random look. See below
I've sort of achieved this effect in moho with a custom brush however due to the brush limitations the results dont look too crisp when making curves or increasing brush size, etc.
moho version:
I could also add more points to lines and simply use the hide edge tool but this would make very simple shapes quite point heavy.
I was curious if this effect was possible with a script? To give the impression of having gaps without having to add points or making a custom brush that is.
SimplSam
Re: [Request] Broken line script
Post by SimplSam »
I would absolutely suggest hide edge. I don't think a few additional points will make an ounce of difference to performance - unless you have some wacky animation of them.
I did also think about masking, but I think that's more work for little-no gain.
8BitHobo
Post by 8BitHobo »
I did experiment with masking but it loses the round edges to the line.
The hide edge is fine for static items like the background but when it come to animating the extra points get a bit tedious.
I might need to experiment with the brushes some more.
Hoptoad
Post by Hoptoad »
8BitHobo wrote: Wed Jul 26, 2023 10:05 am I did experiment with masking but it loses the round edges to the line.
If your lines are squared at the ends, checkmark the box Round Caps in the Style tab. That should round the ends of lines.
I use "Hide Edge" to achieve a gap effect. I like that I can undo any single gap easily by clicking on it again with the Hide Edge tool.
8BitHobo
Post by 8BitHobo »
Hoptoad wrote: Wed Jul 26, 2023 12:20 pm
Oh yeah, I just mean the Lines get cut off when masking >_<
Hoptoad
Post by Hoptoad »
8BitHobo wrote: Wed Jul 26, 2023 3:30 pm Oh yeah, I just mean the Lines get cut off when masking >_<
Oh, think I understand. . .
There may be a way to accomplish what you want, as masking has a lot of variations; for example: Add to Mask But Keep Invisible, and Exclude Strokes.
Of course, what you want to do may be impossible or too difficult without a script, I don't know.
Good luck!
