I'm working on a project, and the backgrounds are all made in this stylized way in Affinity where you can make your lines have dashes. You can specify the gap and the length of the line to give a fairly random look. See below
I've sort of achieved this effect in moho with a custom brush however due to the brush limitations the results dont look too crisp when making curves or increasing brush size, etc.
moho version:
I could also add more points to lines and simply use the hide edge tool but this would make very simple shapes quite point heavy.
I was curious if this effect was possible with a script? To give the impression of having gaps without having to add points or making a custom brush that is.
I would absolutely suggest hide edge. I don't think a few additional points will make an ounce of difference to performance - unless you have some wacky animation of them.
I did also think about masking, but I think that's more work for little-no gain.
I did experiment with masking but it loses the round edges to the line.
The hide edge is fine for static items like the background but when it come to animating the extra points get a bit tedious.
I might need to experiment with the brushes some more.
