Multiple Timelines in a project
Tryll
Post by Tryll »
I think it would be awesome if Moho could save and load multiple timelines in a project. That way you could try animation variations, or create a series of animations which had the same assets.
Re: Multiple Timelines in a project
As long as everything is in the same group layer, you can use actions as separate, test timelines.
Tryll
Post by Tryll »
synthsin75 wrote: ↑Fri Nov 11, 2022 9:06 am As long as everything is in the same group layer, you can use actions as separate, test timelines.
Interesting. I considered using actions but felt that there were probably some limitations I hadn't thought of. I'll probably give that a try.
SimplSam
Post by SimplSam »
Some people have used a master switch group layer (with sub-groups) as a scene switcher. You can also set [View] > [Active Switch Layer Only] for greater visibility distinction.
|- common Foreground (group/layers)
|- Scenes (switch)
. .|- scene 01 (group)
. .|- scene 02 (group)
|- common Background (group/layers)
Tryll
Post by Tryll »
SimplSam wrote: ↑Fri Nov 11, 2022 1:23 pm Some people have used a master switch group layer (with sub-groups) as a scene switcher. You can also set [View] > [Active Switch Layer Only] for greater visibility distinction.
I've done that a bit. It makes for an extremely dense layers panel, and a difficult to maintain project (at least for me.)
While I appreciate the workaround, trying to avoid that is pretty much what prompted the feature request.
I'm thinking of it almost like comps in AfterEffects, or Timelines in Davinci Resolve.
SimplSam
Post by SimplSam »
Yeah - it would be 'great' to move to more of an Asset & Timeline approach - where those elements can be placed into a scene/timeline and not be omnipresent. It would mean a move away from the 'Frame 0' approach.
I would also love to have an 'object-protection' option where assets (groups of layers) are manipulatable (as a whole) but the inners are otherwise protected from non-deliberate selection / edit (i.e. require double click into / right-click edit - to edit).
