Multiple Timelines in a project
I think it would be awesome if Moho could save and load multiple timelines in a project. That way you could try animation variations, or create a series of animations which had the same assets.
Re: Multiple Timelines in a project
As long as everything is in the same group layer, you can use actions as separate, test timelines.
Interesting. I considered using actions but felt that there were probably some limitations I hadn't thought of. I'll probably give that a try.synthsin75 wrote: ↑Fri Nov 11, 2022 9:06 am As long as everything is in the same group layer, you can use actions as separate, test timelines.
Some people have used a master switch group layer (with sub-groups) as a scene switcher. You can also set [View] > [Active Switch Layer Only] for greater visibility distinction.
|- common Foreground (group/layers)
|- Scenes (switch)
. .|- scene 01 (group)
. .|- scene 02 (group)
|- common Background (group/layers)
|- Scenes (switch)
I've done that a bit. It makes for an extremely dense layers panel, and a difficult to maintain project (at least for me.)
While I appreciate the workaround, trying to avoid that is pretty much what prompted the feature request.
I'm thinking of it almost like comps in AfterEffects, or Timelines in Davinci Resolve.
Yeah - it would be 'great' to move to more of an Asset & Timeline approach - where those elements can be placed into a scene/timeline and not be omnipresent. It would mean a move away from the 'Frame 0' approach.
I would also love to have an 'object-protection' option where assets (groups of layers) are manipulatable (as a whole) but the inners are otherwise protected from non-deliberate selection / edit (i.e. require double click into / right-click edit - to edit).
