active tool
davoodice2
active tool
Post by davoodice2 »
Hi friends
is there any way to change moho auto tool selection after select layer?
or activating a tool from script?
Re: active tool
No, not without an external app to hit tool shortcuts. All Lua scripting can do is tell you the active tool: https://mohoscripting.com/methods/1227
davoodice2
Re: active tool
synthsin75 wrote: Sun Dec 26, 2021 11:24 am No, not without an external app to hit tool shortcuts. All Lua scripting can do is tell you the active tool: https://mohoscripting.com/methods/1227
thanks. and
what is benefit of currentTool() ? can you tell me s simple example of usage of that?
Re: active tool
The create shape and add points tools use it like this:
	if (moho:CurrentTool() ~= "LM_AddPoint") then
		return -- this could get called when doing a double-tap on a multitouch Wacom device with a different active tool
	end
davoodice2
Re: active tool
synthsin75 wrote: Sun Dec 26, 2021 1:06 pm The create shape and add points tools use it like this:
	end
understood thanks.
