Hi friends
is there any way to change moho auto tool selection after select layer?
or activating a tool from script?
active tool
- davoodice2
active tool
Re: active tool
No, not without an external app to hit tool shortcuts. All Lua scripting can do is tell you the active tool: https://mohoscripting.com/methods/1227
- davoodice2
Re: active tool
thanks. andsynthsin75 wrote: ↑Sun Dec 26, 2021 11:24 am No, not without an external app to hit tool shortcuts. All Lua scripting can do is tell you the active tool: https://mohoscripting.com/methods/1227
what is benefit of currentTool() ? can you tell me s simple example of usage of that?
Re: active tool
The create shape and add points tools use it like this:
if (moho:CurrentTool() ~= "LM_AddPoint") then
return -- this could get called when doing a double-tap on a multitouch Wacom device with a different active tool
end- Wes
- davoodice2
Re: active tool
understood thanks.synthsin75 wrote: ↑Sun Dec 26, 2021 1:06 pm The create shape and add points tools use it like this:Code: Select all
if (moho:CurrentTool() ~= "LM_AddPoint") then return -- this could get called when doing a double-tap on a multitouch Wacom device with a different active tool end
