write layer script workflow
davoodice2
Post by davoodice2 »
hi.
I want to test my layer script. but each time i have to create new layer and assign script. ctrl+shift+alt+L doesn't work. can any body give a better workflow?
Re: write layer script workflow
I thought I had a script for this - but I can't find it right now -- but if you use MohoLayer:SetLayerScript(path) you can remove and reload the file ..
[edit]oh forget it:
Stan has one: https://mohoscripts.com/script/sz_refresh_layerscript
Lukas
Post by Lukas »
davoodice2
thanks friends.
davoodice2 wrote: Sun Nov 07, 2021 2:22 am hi.
You can actually unembed, hit apply, and reembed, but the scripts make it much faster. My own just reloads all the layerscripts, probably like Stan's.
function Syn_ReloadLayerScripts:Run(moho)
	local count = 0
	repeat
		local layer = moho.document:LayerByAbsoluteID(count)
		if layer then
			count = count + 1
			local script = layer:LayerScript()
			layer:SetLayerScript("")
			layer:SetLayerScript(script)
		end
	until not layer
end
davoodice2
synthsin75 wrote: Sun Nov 07, 2021 2:54 pm
	local count = 0
	repeat
		if layer then
			count = count + 1
		end
	until not layer
end
thanks
