hi.
I want to test my layer script. but each time i have to create new layer and assign script. ctrl+shift+alt+L doesn't work. can any body give a better workflow?
write layer script workflow
- davoodice2
- hayasidist
Re: write layer script workflow
I thought I had a script for this - but I can't find it right now -- but if you use MohoLayer:SetLayerScript(path) you can remove and reload the file ..
[edit]oh forget it:
Stan has one: https://mohoscripts.com/script/sz_refresh_layerscript
[edit]oh forget it:
- davoodice2
thanks friends.
You can actually unembed, hit apply, and reembed, but the scripts make it much faster. My own just reloads all the layerscripts, probably like Stan's.davoodice2 wrote: ↑Sun Nov 07, 2021 2:22 am hi.
function Syn_ReloadLayerScripts:Run(moho)
local count = 0
repeat
local layer = moho.document:LayerByAbsoluteID(count)
if layer then
count = count + 1
local script = layer:LayerScript()
layer:SetLayerScript("")
layer:SetLayerScript(script)
end
until not layer
end- Wes
- davoodice2
thankssynthsin75 wrote: ↑Sun Nov 07, 2021 2:54 pmYou can actually unembed, hit apply, and reembed, but the scripts make it much faster. My own just reloads all the layerscripts, probably like Stan's.davoodice2 wrote: ↑Sun Nov 07, 2021 2:22 am hi.
I want to test my layer script. but each time i have to create new layer and assign script. ctrl+shift+alt+L doesn't work. can any body give a better workflow?Code: Select all
function Syn_ReloadLayerScripts:Run(moho) local count = 0 repeat local layer = moho.document:LayerByAbsoluteID(count) if layer then count = count + 1 local script = layer:LayerScript() layer:SetLayerScript("") layer:SetLayerScript(script) end until not layer end
