Just as I started this post I figured it out. I hardly ever use the sequencer but I needed it for this animation. Cityscape scrolling across the screen but I had a zoom on the camera and needed the cityscape to hold for so many frames. I had already animated the layer before I finished creating all the windows and lights. Even though I was careful to be on frame 0 (guess I missed it once) All the new windows slid over into place at a certain point. I was able to move those keys to frame 0 but was left with key frames that I could not delete. Even tried Clear animation from document. Didn't work. When I figured out why the play head symbol was at frm 400 or so I moved the layer in the sequencer back to the beginning. Now everything is ok and I just have to set up the animation again, which was pretty simple anyway.
I went all the way back to 12.5 to see if it was a bug or something but still could not delete the keys. In hindsight it's probably some sort of fail safe. I was able to delete those key frames after moving the sequencer back to '0'
Deleting key frames not deleting?
Norman McLaren
My Animations
Norman McLaren
My Animations
Re: Deleting key frames not deleting?
That's one of the mistakes I make from time to time.
I hope that one day, probably many years in the future, Moho will have an AI that will detect when a user is making a common interface error, and will display a polite message to the user saying something like, "Excuse me, talented animator, but it seems like you are having trouble trying to (whatever). Might I remind you that..."
Also, the AI will detect when you have finished animating a walk cycle and will play a trumpet sound.
All the bells and whistles would be nice ...but I'd probably uncheck it in preferences and keep making the same mistake
Norman McLaren
My Animations
Norman McLaren
My Animations
Keyframes that can't be deleted are usually a problem with something being keyframed in the timeline without technically having a frame zero keyframe (even though one can sometimes show). To delete these "orphaned" keyframes, they have to be copied to frame zero to "unorphan" them. If there's a lot of such keys on a channel, you can select them all and alt-drag them down to two key before copying them to zero.
