auto set keyframe toggle
davoodice2
Post by davoodice2 »
Hello.
please add this important feature to moho. some time we need to turn it off.
https://pasteboard.co/KbfjfYC.jpg
Re: auto set keyframe toggle
Looks like you're wanting View>Design Mode (Ctrl+Shift+D).
davoodice2
synthsin75 wrote: Wed Jul 14, 2021 11:43 pm Looks like you're wanting View>Design Mode (Ctrl+Shift+D).
No.
Suppose you animate a scene and now you need to import an object and adjust it with character position in frame 250. In this case, going to frame 0 does not help at all. Because I need to adjust with frame 250.
And there are many situations that require this.
Besides, going to zero frame is painful when the scene gets a little heavy.
please see autokey feature in some other software like maya and 3ds max
Maestral
Post by Maestral »
Perhaps something like this...
davoodice2
Maestral wrote: Thu Jul 15, 2021 5:08 am Perhaps something like this...
that is good alternative way.
davoodice2 wrote: Thu Jul 15, 2021 3:23 am
No.
Then simply set an onion skin for the frame you need to match from frame zero. Easy.
davoodice2
synthsin75 wrote: Thu Jul 15, 2021 10:16 am
No.
tricky way. but autokey toggle is much better. accidently key is another problem.
davoodice2 wrote: Thu Jul 15, 2021 12:35 pm
synthsin75 wrote: Thu Jul 15, 2021 10:16 am Then simply set an onion skin for the frame you need to match from frame zero. Easy.
There is no accidental keying if you know it's always keying.
