*NEW-ish* Dock Layers to workspace (Auto-dock on Windows)
This tool keeps layers docked to the workspace, so they are always in view while navigating the workspace.
Very useful to anchor animatics to the workspace or with my Layer Shortcuts script.
Mac: https://drive.google.com/uc?export=down ... CWCV66TqYw
Windows (auto-docking): (Password: synthsin75) https://drive.google.com/uc?export=down ... 3vdBGpOf_q
Directions:
  • Mac:
    1. At frame zero, position and scale one or more layers where you want them docked relative to the workspace window. If you're doing one at a time, you can position/scale it with either layer transforms or workspace navigation, otherwise just use layer transforms to position multiple layers at once.
    2. At frame zero, hit the button and select "Add" to dock all selected layers.
    3. At any frame other than zero, hit the button to restore all docked layers...like after navigation.
    • Tips:
      • Assign this button a shortcut. I used zero.
        Frame zero to add or remove docked layers. You can just hit the first letter of a button, so adding with my shortcut is zero then "a", and removing would be zero then "r".
    1. Assign a shortcut to the "SYN: Dock Layers Use" button. (Necessary for auto-docking.)
    2. At frame zero, position and scale one or more layers where you want them docked relative to the workspace window. If you're doing one at a time, you can position/scale it with either layer transforms or workspace navigation, otherwise just use layer transforms to position multiple layers at once.
    3. At frame zero, hit the "SYN: Dock Layers Set" button (icon with gear) and select "Add" to dock all selected layers or "Remove" to undock all selected layers.
    4. Set layers will now auto-dock on frames other than zero whenever you:
      • Use right-click & drag to pan the workspace.
      • Use mouse wheel scroll to zoom the workspace.
        • This might not work with touchpad or touch screen zoom gestures, but you can simply right-click after zooming to auto-dock.
      • Use Shift+right-click & drag to zoom workspace.
      • Use Home to reset the view.
      • Use Home+Shift to zoom layer contents.
      • Use Home+Alt to zoom selected points.
    • Tips:
      • Assign "SYN: Dock Layers Use" button a shortcut, but you'll never need to use it, so it can be any available key.
        All the auto-docking only works if you release the key/s, like right-click & drag, within the workspace. This is so the automation doesn't affect anything else in Moho that may use the same key/s.
      AutoHotkey script:
      • If you have AutoHotkey installed and wish to use the uncompiled AHK script instead of the compiled exe:
        • With Moho closed, open "syn_dock_layers_set.lua" in a text editor, like Notepad.
          Under "Recurring values", change the value of "Syn_DockLayersSet.exe" from 1 to 0.
          Open Moho, and when you go to dock a layer, it will ask you to find your AutoHotkeyU64.exe
lucasfranca
Re: *NEW-ish* Dock Layers to workspace (Auto-dock on Windows)
Post by lucasfranca »
Link off?
https://youtube.com/animai2D
lucasfranca wrote: ↑Thu Aug 12, 2021 8:13 am Link off?
Links fixed.
gilcartunista
Post by gilcartunista »
synthsin75 wrote: ↑Thu Aug 12, 2021 8:35 am
Links fixed.
Link off...
gilcartunista wrote: ↑Thu Aug 12, 2021 8:40 am Link off...
They work here. Don't know what to tell ya.
gilcartunista
synthsin75 wrote: ↑Thu Aug 12, 2021 8:44 am
This is the message that appears to me...https://ibb.co/svmW738
I just tried in Chrome and, yeah, I'm seeing the same error page for both links, Mac or Win.
In Firefox, I get a screen asking me to sign-in to Google Drive.
Okay, try them now.
Google Sites migrated to Google Drive, and I had found something that said I could still make them hotlinks, but apparently that doesn't work.
Hi Wes,
Now I'm seeing (in Chrome) the same sign-in screen I'm seeing with the Layer Shortcuts link. (viewtopic.php?f=12&t=32641&start=120#p198719)
synthsin75 wrote: ↑Thu Aug 12, 2021 9:31 am Google Sites migrated to Google Drive...
Ugh...hate when that stuff happens.
Seems all good now...tested both Mac and Win links. 👍
gilcartunista
gilcartunista wrote: ↑Thu Aug 12, 2021 8:49 am
Seems all good now...tested Win link. 👍
lucasfranca
The link now works, thanks! But I have a problem in version 13.5: This problem appears :(
I duplicated the folder and renamed it to Micro smith, problem 2 appeared.
lucasfranca wrote: ↑Fri Aug 13, 2021 3:01 am The link now works, thanks! But I have a problem in version 13.5: This problem appears :(
Okay, I've updated it for v13.5.
Cool! Thank you Wes. Funny, I remember you releasing this tool a while back but I somehow missed trying out.
Will definitely install and try it this weekend.
Greenlaw wrote: ↑Fri Aug 13, 2021 10:33 am Cool! Thank you Wes. Funny, I remember you releasing this tool a while back but I somehow missed trying out.
Just noticed I forgot to comment out a print call. Updated again.
