*NEW* Track Stroke Exposure
Here's a menu/button script to track stroke exposure.
https://drive.google.com/uc?export=down ... E8rILAjsYH
1. Create any shape with stroke exposure End Percentage animation.
2. Run the script.
It will create all the needed groups, reference, and animate follow path to track stroke exposure End Percentage. The "faux_camera" group can be used to animate the whole setup instead of using the camera.
If you change the stroke exposure animation, you can run the script again to update the tracking. Make changes to the original layer, which is set to hide in editing and not render.
Stan
Re: *NEW* Track Stroke Exposure
Post by Stan »
Nice script, Wes, thank you for sharing!
I should mention that there is a nasty little bug in Moho that stroke exposure percentage is calculated differently then follow path percentage. This creates discrepancies, especially when the curve contains straight lines and sharp corners.
I once tried to make a layer script that would move a pencil along the stroke exposure, and the result was not really good because of that bug.
This is an illustration of the issue - see, it works perfectly for circles but totally fails on squares:
And this is an example made with your script:
Oh, yeah that is a pretty bad bug. Stroke exposure seems to interpolate between points according to curvature. That's strange. Exposure doesn't have any bezier keyframe handles either.
EDIT: M_Curve:GetPercentLocation(percent) doesn't even match the stroke's visual location, so this script might be as good as it's going to get for now.
Stan
Post by Stan »
synthsin75 wrote:EDIT: M_Curve:GetPercentLocation(percent) doesn't even match the stroke's visual location, so this script might be as good as it's going to get for now.
Yeah, and this is a good example of a bug that needs to be fixed on the core application level and not on the interface level.
I've reported the problem.
In the meantime, one thing that helps is to have less space between points on the curve. So using, Scripts>Draw>Split Curve can help the end result.
The discrepancy increases as the stroke has more ground to cover between points. It almost looks like there's a smooth interpolation from point to point, but a smaller distance is covered too quick for this to be apparent...like keyframes on the timeline.
This is very interesting. Thanks, Wes!
Did you create it with a specific idea in mind? I'm trying to think where I could use it :)
Maestral
Post by Maestral »
To me, it looks like a perfect way of depicting birdseye view character`s tracking/following over some map or some closeup (tailoring or cutting some fabrics). Either way, some sort of extreme POV.
Víctor Paredes wrote:This is very interesting. Thanks, Wes!
This: viewtopic.php?f=13&t=32559
But it could also be used to animate following a pen as it writes.
Shizukuishi
Post by Shizukuishi »
Hi Wes, do you still have a copy of this script? Link is broken
Even with the head in the clouds You can touch the ground
https://marisolpetretto.myportfolio.com/
https://www.linkedin.com/in/marisolpetretto/
Here's the new link (updated first post): https://drive.google.com/uc?export=down ... E8rILAjsYH
Somehow, I missed this one when it was originally posted, but I'm glad it resurfaced today! Will try it out shortly. :D
Shizukuishi
synthsin75 wrote: Mon Aug 11, 2025 1:47 pm Here's the new link (updated first post): https://drive.google.com/uc?export=down ... E8rILAjsYH
Thanks a lot! :D
