《威龙矩阵》二代,肢体控制器=)Dragon Matrix
chucky
Re: 《威龙矩阵》二代,肢体控制器=)Dragon Matrix
Post by chucky »
Astonishing Sang!
amazing stuff. does the limb/body version of Dragon Matrix work with multiple views in the same way as the head version?
sang820
Post by sang820 »
hayasidist wrote:amazing stuff. does the limb/body version of Dragon Matrix work with multiple views in the same way as the head version?
:shock: 喔,是不同的机制。肢体的龙矩阵=A肢体旋转+B肢体缩放+目标骨骼+插件协调机制。 :shock:
:shock: 头部的龙矩阵=多角度样本+按照百分比调用+插件协调机制。 :shock:
:roll: 目前的肢体龙矩阵有个巨大的缺陷,来自模型结构的缺陷。我目前仍没有解决方向.... :roll:
sang820 wrote:目前的肢体龙矩阵有个巨大的缺陷,来自模型结构的缺陷。我目前仍没有解决方向.... :roll:
thanks for the explanation. I hope you get the issues you've mentioned sorted out!
sang820
Post by sang820 »
:D 谢谢,我的朋友,我会努力解决这个难题 :D
eric1223
Post by eric1223 »
Good work as usual sang =). Before seeing ur example, I have had a hard time figuring out when to use pin bones. This inspires me to try to use pin bones more.
sang820
Post by sang820 »
eric1223 wrote:Good work as usual sang =). Before seeing ur example, I have had a hard time figuring out when to use pin bones. This inspires me to try to use pin bones more.
:shock: 加油,我的朋友,你会有更多的收获 :shock:
devproject
Post by devproject »
i still don't understand about Dragon Matrix, its plugin, or Dragon Matrix Rigging all bone for us ?
sang820
Post by sang820 »
devproject wrote:i still don't understand about Dragon Matrix, its plugin, or Dragon Matrix Rigging all bone for us ?
:shock: 龙矩阵是外部插件。基础骨骼在moho创建,以龙矩阵的规则运行这些骨骼、模型。 :shock:
