《威龙矩阵》二代,肢体控制器=)Dragon Matrix
Re: 《威龙矩阵》二代,肢体控制器=)Dragon Matrix
Astonishing Sang!
- hayasidist
amazing stuff. does the limb/body version of Dragon Matrix work with multiple views in the same way as the head version?
hayasidist wrote:amazing stuff. does the limb/body version of Dragon Matrix work with multiple views in the same way as the head version?
- hayasidist
thanks for the explanation. I hope you get the issues you've mentioned sorted out!sang820 wrote:目前的肢体龙矩阵有个巨大的缺陷,来自模型结构的缺陷。我目前仍没有解决方向....
hayasidist wrote:thanks for the explanation. I hope you get the issues you've mentioned sorted out!sang820 wrote:目前的肢体龙矩阵有个巨大的缺陷,来自模型结构的缺陷。我目前仍没有解决方向....
Good work as usual sang =). Before seeing ur example, I have had a hard time figuring out when to use pin bones. This inspires me to try to use pin bones more.
eric1223 wrote:Good work as usual sang =). Before seeing ur example, I have had a hard time figuring out when to use pin bones. This inspires me to try to use pin bones more.
- devproject
i still don't understand about Dragon Matrix, its plugin, or Dragon Matrix Rigging all bone for us ?
devproject wrote:i still don't understand about Dragon Matrix, its plugin, or Dragon Matrix Rigging all bone for us ?
