Script for switching multiple switches simultaneously
chucky
Post by chucky »
I have a situation with switches inside switches and a LO them
I would like to be able to switch a lot of them ( within a group) at the same time ( they have consistent names), rather than trawling through all the layers to switch them manually which takes 'stoopid' time.
So my obvious next question is... does anyone have a script for that?
:roll: :) :roll:
Re: Script for switching multiple switches simultaneously
I have the idea I saw a script for that in the past (probably a very old one), but what about using References instead?
chucky
Post by chucky »
Víctor Paredes wrote: what about using References instead?
I can't see that working in this 'instance' ... sorry for the pun.
Seriously though that would get too messy for my liking and I'm way too far down the track for that. :?
Víctor Paredes wrote:I have the idea I saw a script for that in the past (probably a very old one),...
this one?
http://lostmarble.com/forum/viewtopic.php?f=12&t=27094
chucky
Post by chucky »
Hey thanks!
OH this works brilliantly... even in my switch within a switch... took a little braining ... but yeah ... thanks guys!
I'd love to see this as a layer checkbox built in...
chucky
Post by chucky »
Hey, I wonder if the same type of script could 'trick' interpolation in nested layers ?
chucky
Post by chucky »
I also wonder if it could be adapted for visibility , when switch groups can't be used due to the 'exclude strokes' masking limitation.
chucky wrote:Hey thanks!
yes - it's neat -- doesn't (yet) deal with cycle keys tho.
and +1 to making this a standard feature.
chucky wrote:Hey, I wonder if the same type of script could 'trick' interpolation in nested layers ?
it could probably be extended do that (with all the same limitations as interp now - e.g. same number of points in essentially the same sequence(s) in path(s) - straight-line displacement... ) -- something along the lines of getting the point position in the active child; get the point position in the "to be active" child; and number-crunch the difference -- similar in concept to the "follow target bone in a different layer" (http://lostmarble.com/forum/viewtopic.php?f=13&t=31302)
chucky wrote:I also wonder if it could be adapted for visibility , when switch groups can't be used due to the 'exclude strokes' masking limitation.
well, IMO yes - any attribute in a "master" can be accessed and applied to a "slave" -- this script looks for keys frames in SwitchValues - a variation could easily look for keys in layer visibility
chucky
Post by chucky »
Yes that idea of a visibility variant , would really help me.
I can see this script is super short..wow!
If only I knew the first thing about this stuff. Guess it would be a matter of maybe changing a few of the words?
And instead of
if (Layer:LayerType() == 5) then --CHECK FOR SWITCHLAYER
it might look for the layer visibility value?
See I'm already out of my depth, but to my inexperienced eye , is it that only three or four lines need to change?
function LayerScript(moho)
	local ControlLayer = moho.layer
	local Parent = moho.layer
	function SlaveCheck(Parent)
		local group = moho:LayerAsGroup(Parent)
		for i=0,group:CountLayers()-1 do
			local Layer = group:Layer(i)
				Layer = moho:LayerAsSwitch(Layer)
				local name = ControlLayer:Name() .. ".SLAVE"
				if name == Layer:Name() then
					local master = ControlLayer:SwitchValues()
					if master:HasKey(moho.frame) then
						Layer:SwitchValues():SetValue(moho.frame,master:GetValue(moho.frame))
					elseif Layer:SwitchValues():HasKey(moho.frame) then
						Layer:SwitchValues():DeleteKey(moho.frame)
					end
				end
			end
			if Layer:IsGroupType() then
				SlaveCheck(Layer)
			end
		end
	end
	while go == nil do   --FIRST LOOK FOR MASTER CHARACTER LAYER
		Parent = Parent:Parent()
		if Parent == nil then
			break
		else
			local CheckMaster = string.match(Parent:Name(),".MASTER")
			if CheckMaster ~= nil and Parent:IsGroupType() then
				SlaveCheck(Parent)
				break
			end
		end
	end
end
chucky wrote:Yes that idea of a visibility variant , would really help me.
I've had a longer ponder and I think there are many ways to pluck the pelt from that proverbial pussy ... and the exact scripting solution depends on how you want to organise / use your file.
one option:
Group Layer
> child layers
layer script to look for a new "visibility on" key in a child layer and set all the others to "visibility off" (i.e. the "visibility variant")
another option:
Group Layer
> child layers
(tool) script (based on the standard LM_SwitchLayer tool) to set visibility on for just one chid layer (i.e. to simulate a switch)
yet another option:
Group layer
>real child layers
Switch layer
> dummy child layers each named as per the Group
(layer) script the Group layer to toggle visibility of its child layers to match the selected switch layer
(as a sub option one set of child layers might hold fill vectors and the other holds the strokes - and use the appropriate one as a mask -- but if you're going in that direction you might just as well have two switch layers and use the current script solution)
(optional tool script to auto-generate the dummy child layers)
IMO a tool script based on the standard LM_SwitchLayer tool is probably easiest from a usability point of view
thoughts??
chucky
Post by chucky »
Well the pussy seams to be half skinned already, it seems.
THis slave visibility would be the most expedient for me.
I have a working solution but it involves many, many, many layers and is boring to work with.
Any other solution could be even worse.
It all really down to the fact that there is no option to exclude strokes from masks inside a group.
I'm way too far into the project to rebuild too much now. I've posted a screener.
You can see the layer script slaving the teeth layers and working nicely.
So I'm using a top level switch with references of the whole kit and caboodle, which triples the layer count and I had to toggle off each lip option for all three reference groups. It feels like I'm wearing a hat with a hat and a hat on top.
Slaving the visibility would be much cleaner .
Oh yes, I'm obviously just hiding the layer rather than toggling visibility, it's clearer for now.
so to check that I understand this - you have multiple instances of (say) Top Heavy Lips (vector) and when the master one gets its visibility changed then all the others should too? (Not too tricky)
or is it if the master Top Heavy Lips (vector) gets its visibility changed then as well as all slave Top Heavy Lips changing, all Thin Lips and Thick Lips (and ..) need to have their visibility changed too? (trickier)
and is this just a frame zero set-up (or is it timeline animated)?
and are the multiple instances of the character set-up top-level group in a file?
((a main difference between the visibility variant and the switch base version is that a master for visibility could be any type of layer (vector, group, ...) so the actual way of finding a master and its slaves is not quite the same as the way the original code looks for switch layers))
chucky
Post by chucky »
So, instead of switching between those large 'red' groups, I just have the one red group that contains all the lips.
So when I change the master ('pink' top heavy lips) to on, then all the pink top heavy lips inside the 'coral' phoneme/expression sub groups change too.
I won't need the top level 'red' top heavy groups any more and I will delete those, there will just be the coral coloured groups under the selected mouth group.
Is that the simper version?
It's all pretty hard to explain/follow with words eh? :?
Oh it doesn't need to animate and it would only be in that one red mouth folder
is this right?
file contains one switch for mouth types
each mouth type child has a switch for phoneme
each phoneme child has vectors for all mouth types
whichever child of "mouth types" is active make the corresponding vectors in all phonemes active and make all the rest not visible
e.g.
mouth type active child is "fat"
for all phonemes in "fat"
> make visible all vectors for "fat"
> make invisible all vectors for other mouth types
chucky
Post by chucky »
Ahh that 's a good way to explain.
I would like to have this....
File contains switch for phonemes called mouth.
Each phonemes has lips that mask the other layers.
Each phonemes has lip types ( three so far)
On of the phonemes is the master.
Change the visibility of lips in the master phoneme and the lips in all the phonemes correspond.
This is different , to what I have shown, which is the current setup with mouth types.
I want to delete the mouth types just , even though it is working , just because it is unwieldy and inelegant.
I'll the have one mouth only.
