How to add glow to eyes?
RyanSurrey
Post by RyanSurrey »
i am trying to make a of cartoon with glowing eyes. for reference, they look something like this at 0:30
https://www.youtube.com/watch?v=_vycUIW_tsA.
Thanks
marineboy
Re: How to add glow to eyes?
Post by marineboy »
Hi
Try using the Soft Edges effect on a Fill/shape. You can adjust the parameters to change the range of the 'fall off' of the edge - for more or less 'glow'. This can give a nice sort of Neon Light effect if you use it with the brightest Green, Red or Blue. Your PPG's example has the outer edge of the eye glowing a lighter/brighter colour - maybe experiment with overlaying a slightly darker shape on top of the lighter one to achieve this.
RyanSurrey
marineboy wrote:Hi
Not Working mate. Its just blurring the colour but not give that 'glow'
chucky
Post by chucky »
To make the glow effect you will have to use a soft edge shape on a separate layer that is using the blend method 'add'.
http://charleskenway.com/anime/members/ ... rough.moho
Glows have to work on darker backgrounds and when using add use a dark well saturated colour for the best effect.
RyanSurrey
chucky wrote:To make the glow effect you will have to use a soft edge shape on a separate layer that is using the blend method 'add'.
That Is Working mate. I think the main factor is blend method.
chucky
Post by chucky »
No worries :)
SemiRespect
Post by SemiRespect »
chucky wrote: ↑Thu Jun 15, 2017 5:28 am To make the glow effect you will have to use a soft edge shape on a separate layer that is using the blend method 'add'.
This is gone now but I'd love to have seen it, is there any way to retrieve the info?
