Sunrise layer
shepherdlamb
Sunrise layer
Post by shepherdlamb »
I'm trying to make the sky or the feel of my stage go from night time to daylight. Can anyone explain the best way to accomplish this. Much thanks.
drumlug13
Re: Sunrise layer
Post by drumlug13 »
You can animate the colors of a shape. For example you can use a dark blue rectangle as your background, move down the timeline, select your triangle with the 'Select Shape' tool (shortcut Q), then change the color of the rectangle to a light blue or orange'ish color for the sunrise.
the color of the rectangle will change as the animation plays.
Adam
shepherdlamb
Re: Sunrise layer
Thank you drumlug, I was able to filter the whole scene using your suggestion and adjusting the alpha channel with the select shape tool. Awesome.
drumlug13
Re: Sunrise layer
Post by drumlug13 »
You're welcome, I use that trick quite often myself.
Adam
