video for web
bender
video for web
Post by bender »
Hello.... finally I have finished my first work with moho, it´s a 7 min video with an excellent quality of image, that I´d like to keep, but in it´s original form have a weight of something like 1 Gb....... so I need to compress the file in order to be able to publish it over the internet....... I´m thinking in 320 x240 screen size and 25 fr/sec..... But with the codec I´ve tried (windows media encoder, wmv)I reached 18 mb files, with a good quality but the require a very high data transer rate .....
Do somebody know a codec or a program that I could use to compress the file in order to have a good image quality and a lower data transfer rate????
Thanks for the info....... as soon as I have my work published I´m going to put the link in the forum to show it to you
kdiddy13
Use a lower frame rate
Post by kdiddy13 »
WMV should be pretty good.
I'd highly recommend you try a lower frame rate (like 12 fps or 15, half the rate of your original), it should look good and be about half the size. At 7 minutes you probably won't get it much below 10mb (it can vary depending on what's the video of course).
________
Lamborghini revent?n
pintman
Post by pintman »
Try Sorenson3 of Quicktime. It's really great in compression.
bakera.de - home sweet home
bulb-publications.de - films sweet films
mr. blaaa
Post by mr. blaaa »
i think 10-20 MB will be fine already if it's worth the download :wink:
(i would even accept up to 60 MB)
bender
thanks
Post by bender »
ok..... I´m going to try some of the solutions that you gave me, thanks
GCharb
Post by GCharb »
Hello there.
Quicktime 7 has h264 compression, it is really good and gives compact files with high quality but you need to register Quicktime pro which is 29$.
Would make it easier on Mac users and Linux since wmf is a microsoft codec, not sure how well it is suported on Macs and Linux systems, just a thought.
I also like the xvid codec, which is free and really good, creates avi's.
