Set origin
Asterix
Set origin
Post by Asterix »
Can I center a object to the origine (0)?
Thanks
ASP 7.1
sbtamu
Re: Set origin
Post by sbtamu »
select every point of the shape then select the translate points tool and set x and y to a value of 0(zero.)
Sorry for bad animation
Re: Set origin
sbtamu wrote:select every point of the shape then select the translate points tool and set x and y to a value of 0(zero.)
Oh, I never thought on that! Good tip, thanks sbtamu!
InfoCentral
Re: Set origin
Post by InfoCentral »
And you need to be on the vector layer to select them.
