Can I center a object to the origine (0)?
Thanks
Set origin
Set origin
ASP 7.1
Re: Set origin
select every point of the shape then select the translate points tool and set x and y to a value of 0(zero.)
Re: Set origin
Oh, I never thought on that! Good tip, thanks sbtamu!sbtamu wrote:select every point of the shape then select the translate points tool and set x and y to a value of 0(zero.)
- InfoCentral
Re: Set origin
And you need to be on the vector layer to select them.
MEETUP.COM - start or join a group
