how import video to AS and don't get a broken icon
Hi..I'm trying import an animation for copy the movement but everytime than I try I get an icon with a broken sign..I've tried several formats, flv, mpeg, avi, etc..and always happen the same, only can see the animation than I did in AS and exported like video...I don't know if it is related about the mocap, because appear a little red circle in the center and I can expand, move, etc...but my animation doesn't appear, only a broken symbol....
Hi...here is the image
http://dl.dropbox.com/u/15864219/error.JPG
thanks
thanks
Acesonnall wrote:Mind showing a picture? (ctrl+alt+Print Screen, if using windows). I don't know what you mean by broken icon.
nope..I've changed the name to "aa.avi" and it still doesn't work
slowtiger wrote:That "broken" icon only means that AS can't find the file.
If the video file format is correct (see manual for reference), see if it's named correctly. AS is known to have trouble with non-ASCII-7-characters (like the german äöüß).
here is the link
http://dl.dropbox.com/u/15864219/banim.avi
I don't think can be a problem with quicktime because it's an avi video, and yesterday I've installed a codec pack without luck...try if you can see it...
jonbo wrote:Try installing QUICKTIME, if you have it already, make sure its the most recent version by re-installing it. This helps sometimes. If possible, upload a 10 sec clip of the video to a file share site so we can check it on our end.
This one will import into AS. all though the size is smaller.
http://www.mediafire.com/?dhs2mceyre57bmr
- neeters_guy
yes..I think than is a quktime problem...actually I'ven't any problem for play any kind video with vlc and after this problem I've installed a full codec pack but was only when I install quiktime than this work inside AS....
sbtamu wrote:It will play on VLC but no where else. So I just converted it for him and uploaded a link.
