how import video to AS and don't get a broken icon
cocoOS
Post by cocoOS »
Hi..I'm trying import an animation for copy the movement but everytime than I try I get an icon with a broken sign..I've tried several formats, flv, mpeg, avi, etc..and always happen the same, only can see the animation than I did in AS and exported like video...I don't know if it is related about the mocap, because appear a little red circle in the center and I can expand, move, etc...but my animation doesn't appear, only a broken symbol....
Acesonnall
Post by Acesonnall »
Mind showing a picture? (ctrl+alt+Print Screen, if using windows). I don't know what you mean by broken icon.
~Ace
Want to see my other (older, but still cool/funny) animations? Click the picture below!
cocoOS
Post by cocoOS »
Hi...here is the image
http://dl.dropbox.com/u/15864219/error.JPG
thanks :D
Acesonnall wrote:Mind showing a picture? (ctrl+alt+Print Screen, if using windows). I don't know what you mean by broken icon.
That "broken" icon only means that AS can't find the file.
If the video file format is correct (see manual for reference), see if it's named correctly. AS is known to have trouble with non-ASCII-7-characters (like the german äöüß).
cocoOS
Post by cocoOS »
nope..I've changed the name to "aa.avi" and it still doesn't work :cry: :cry: :cry:
slowtiger wrote:That "broken" icon only means that AS can't find the file.
jonbo
Post by jonbo »
Try installing QUICKTIME, if you have it already, make sure its the most recent version by re-installing it. This helps sometimes. If possible, upload a 10 sec clip of the video to a file share site so we can check it on our end.
cocoOS
Post by cocoOS »
here is the link
http://dl.dropbox.com/u/15864219/banim.avi
I don't think can be a problem with quicktime because it's an avi video, and yesterday I've installed a codec pack without luck...try if you can see it...:):)
jonbo wrote:Try installing QUICKTIME, if you have it already, make sure its the most recent version by re-installing it. This helps sometimes. If possible, upload a 10 sec clip of the video to a file share site so we can check it on our end.
jonbo
Post by jonbo »
It plays fine for me. Try what I said, even though it sounds stupid, it has been known to work. Or try to re-install Anime Studio.
sbtamu
Post by sbtamu »
I cant get it to load into As either. There is a problem with the codec you used.
Where did you get that video? There is something wrong with it.
Sorry for bad animation
sbtamu
Post by sbtamu »
This one will import into AS. all though the size is smaller.
http://www.mediafire.com/?dhs2mceyre57bmr
neeters_guy
Post by neeters_guy »
Inspecting the fourcc header indicates that this uses "DIVX = OpenDivx v4" codec. You'll need to install this codec on your system in order for to play/use it.
sbtamu
Post by sbtamu »
It will play on VLC but no where else. So I just converted it for him and uploaded a link.
jonbo
Post by jonbo »
Well, that would explain why it works for me. I have that codec installed.
cocoOS
Post by cocoOS »
thnk so much mn..I've downloaded the quiktime and this work!!..great..thanks!! :D:)
jonbo wrote:Well, that would explain why it works for me. I have that codec installed.
cocoOS
Post by cocoOS »
yes..I think than is a quktime problem...actually I'ven't any problem for play any kind video with vlc and after this problem I've installed a full codec pack but was only when I install quiktime than this work inside AS....
sbtamu wrote:It will play on VLC but no where else. So I just converted it for him and uploaded a link.
