strange thing about swf format??
The most likely explanatiion is that one or more points are directly on top of each other in one of your shapes. It means going back over your shapes and tweaking each and every point to see where the problem lies. It's a time-consuming pain in the arse, but I haven't found a quicker way...
It's usually some kind of discrepancy in the way your shapes have been constructed. Save a copy of your work, then try leaving out one shape at a time while you render to swf. That should enable you to find the problem; when you do, it might be quicker to just rebuild that shape rather than try to fix it...
wow! that is awesome!
Your answer is awesome! I followed your instruction and settled the problem. Then there poped up a new problem: I want an advertising slogan to jump out one word by another, and I created the words in png files individually, then back to Anime, I let them to be invisible at first, and become visible when they should appear. When I export the file to SWF, some blocks jumped out from nowhere! I have examined everything, still confused................
Thank you so much!
Sorry I forgot to say thank you so much, and I really appreciate your help! You probably found my English not so good, the reason being that English is my second language.
SWF export from Anime Studio has not been improved in years. I have complained about it in the past, but nothing ever seems to get done. It's obviously a low priority...
If you have Flash, then what you describe would be easier to do in Flash. Export the swf file from AS into Flash, and then animate the slogan in Flash.
If you don't have Flash, then try to steer clear of bitmaps like png files - they cause problem when exporting to swf. Try typing out the slogan in Anime Studio using the text tool and see if that is any better. Do a short test first to see if it behaves like you want it to.
thanks again
Well, then I will try Flash as see if i can manage it. Actually I found the problem of the png file: Since the slogan is in Chinese, the English Anime is unable to type the characters, so I must make the characters in png with photoshop. Then in Anime, the transparent part of png pops out into solid squares, instead of being invisible..... as you said, they should improve the software.
Ha ha! It's funny if you can't see it.slowtiger wrote:Sorry? I did that successfully in the past. It works if you don't use "warp with bones", use layer binding only, and don't use any other rotation than around Z.if you mix bitmaps and bones it's not going to export to swf format
- funksmaname
