Video Tracking an Image Sequence
dp4
Post by dp4 »
is there a way to create a tracker path on a "video" that consist of an image sequence (imported via Script->Image Sequence)?
thanks!
ruscular3d
Post by ruscular3d »
It would be a great feature to implement something that Adobe after effect has. I think if I were to do this is to make an oversize video of the footage with extra outside blank area and use after effect to stabilize the subject that you wish to track, then place the animation in it and then resize the video back to normal and re-stabilize the edge to final output. If you have a long footage it may save time rather than manually track a subject inside Anime Studio.
dp4
Post by dp4 »
ruscular3d Thank you!
Stabilize, animate in AS, and then remove the stabilization could be an option.
Although i'm not quite sure if it works with z-movement, i have footage with zooms and the tracking information needs to be combined with the scaling of the AS-object.
The problem is to stabilize the source-footage in z, so i think it must be scaled. x,y movement shouldn't be the problem.
I don't use AE so i have to try it in my compositing tool.
ruscular3d
yes that is exactly correct! You will have to do your best to scale your animation to fit the "Z" axis
I am glad you understood the idea. It's not easy to explain but you summarize it really well!
