Curve profile hidden width feature
I just discovered a very nice effect. Check this video (it's two minutes, you won't regret)
https://www.dropbox.com/s/i30vhjcy4zlvu ... t.mp4?dl=0
Wow! That is fantastic! Thanks for sharing...
You are welcome.
It's fantastic, this technique let you animate the width in way never possible before:
Poptoogi
Wow
Post by Poptoogi »
That's freakin awesome Selgin!!!!! Amazing technique!!! Thanks for sharing!
Practice random acts of kindness and senseless acts of beauty! Pause, consider, do! I dare you!
wow nice find!
in the preview, the overlapping line creates gaps - does that not get rendered?
THanks again Selgin.
dueyftw
Post by dueyftw »
Miyazaki uses a technique of paining another layer of grass moving over top of a background layer of grass. Changing the colors to darker and lighter than the background. Normally in a random v shape and done on three's I think. Looks like the wind is blowing through the grass.
This might be a good way of mimicking Miyazaki technique.
Dale
interesting idea dale - I played around and came up with this...
it's not great, I've never really played with particles before, but maybe it can be used as a base for something?
http://youtu.be/U0vXS-DcfyA
http://www.mediafire.com/?b633cs9ut7yswmm for the file
The emitter follows a path, and although its hard to see, the grass line (path profile source) actually animates over time
Could be great for water too...
Awesome!
dueyftw
Post by dueyftw »
neon22
Post by neon22 »
wow!
Can't try this with my version, but wouldn't it be possible to do the same with switched-off line segments? So you can create a complicated "walking ants" line easily?
slowtiger wrote:Can't try this with my version, but wouldn't it be possible to do the same with switched-off line segments? So you can create a complicated "walking ants" line easily?
If I understood well, yes, you can do that. Anyway, I think it would be better to use the follow path tool for that task. Just create a vector layer with a row of ants, and then attach it bended to the path.
I'm still on 6.2 *g* But I have my methods when I need an effect like that.
slowtiger wrote:I'm still on 6.2 *g* But I have my methods when I need an effect like that.
On 6.2 you can use a bone path with similar results (you already know it, but maybe could help someone)
viewtopic.php?t=13230
Exactly that.
BTW: I keep a kind of "library" of things like this which are quite useful for a lot of different jobs. In creating these I found that it pays to only animate group layers. which can be filled with whatever content later easily.
