I am looking forward to seeing some examples of the embedded scripts that one can use.
I can not write scripts - I do not have the brain power to accomplish it.
I am curious to see examples of them working, because right now I have a problem grasping their usefulness.
For example, one can supposedly write a script so that object A points at object B. But why couldn´t I just do that by hand? And won´t there be lots of unpredictable problems that occur - such as it points in a manner one does not want or one can´t turn it off at a later point in the animation. Or it conflicts with the "face the camera" function? Or it does not work well for 2D objects in a 3D environment.
I look forward to seeing what people come up with. When people write the scripts I hope they include a sample animation to show how it works.
Because if it is good and useful you can count on at least one person here using it!
Like that kind of script is not accesible by menu, you can put it where you want or prefer... I personally have created a new folder named Embedded inside script folder of moho directory...
If you plan to write re-usable scripts, you could put them in the embedded folder. On the other hand, if you write an embedded script that is very specific to one particular Moho animation, I would keep it in the same folder as the Moho file itself.
