Embedded Scripts in 5.2
Toontoonz
Post by Toontoonz »
I am looking forward to seeing some examples of the embedded scripts that one can use.
I can not write scripts - I do not have the brain power to accomplish it.
I am curious to see examples of them working, because right now I have a problem grasping their usefulness.
For example, one can supposedly write a script so that object A points at object B. But why couldn´t I just do that by hand? And won´t there be lots of unpredictable problems that occur - such as it points in a manner one does not want or one can´t turn it off at a later point in the animation. Or it conflicts with the "face the camera" function? Or it does not work well for 2D objects in a 3D environment.
I look forward to seeing what people come up with. When people write the scripts I hope they include a sample animation to show how it works.
Because if it is good and useful you can count on at least one person here using it!
Toontoonz
Post by Toontoonz »
Dumb question: In which scripts folder does one place the embedded script .lua file:
-Menu
-Tool
or
-Utility?
Rai López
Post by Rai López »
Like that kind of script is not accesible by menu, you can put it where you want or prefer... I personally have created a new folder named Embedded inside script folder of moho directory...
Toontoonz
Post by Toontoonz »
Thanks! And good idea for the new folder.
Lost Marble
Post by Lost Marble »
If you plan to write re-usable scripts, you could put them in the embedded folder. On the other hand, if you write an embedded script that is very specific to one particular Moho animation, I would keep it in the same folder as the Moho file itself.
Rai López
Post by Rai López »
Yes, that's true, to maintain the paths if you move your proyect of one location to another... THANK YOU! (for this and for all).
