Can it be used for things like scene changes? Instead of putting individual scenes together in an external movie editor can separate videos be lined-up in the sequencer and re-rendered? At least I would then be able to sync all my clips to a single music track.
I started studying particle layers last night wondering what it would take to create an 'explosion in space'. This is such a large subject that I might have to put it off for a while.
Why use "Do Not Premultiply Alpha"?
Cheers, Larry
"Pre-Multiply Alpha" is a term used for rendering images on a transparent background. The two options are "Pre-Multiply Alpha" and "No Pre-Multiply Alpha". The first one is useful for darker outlines, the second for lighter outlines, and they'll prevent to have thin white or dark rims later in compoisting images on a background image.
- hayasidist
hi. also if you have soft edge then without "do not premultiply" the soft edge is blended with the bg colour ... as I found out the hard way ...
viewtopic.php?p=105407
with "do not premultuiply" the bg does appear not to be blended into partially transparent areas. (and apols to Ramón cos I forgot to say thanks back then!)
