A newbie question: I understand Illustrator files import as a single layer. How, then, does one move selected vectors into new AS layers (for example, separating a head illustration's eyes into a separate layer).
Thanks,
Break apart Illustrator file in AS layers
- funksmaname
- funksmaname
the problem is probably the complexity of illustrator shapes and sheer number of shapes/fills and points. In some ways its easier to just flatten the layers you want to high res raster parts in illustrator - breakapart script will probably justt give you a zillion unusable shapes across lots of layers...
the easiest way if you insist on importing illustrator is to split them up IN illustrator where you have best control of the shapes as they are at that point. once you bring it into AS and have to split them with millions of points your life is instantly complicated.
