Break apart Illustrator file in AS layers
RBuday
Post by RBuday »
A newbie question: I understand Illustrator files import as a single layer. How, then, does one move selected vectors into new AS layers (for example, separating a head illustration's eyes into a separate layer).
Thanks,
save separate illustrator files...?
jonbo
Post by jonbo »
If you have AS8, you could try the RT: Break Apart Shapes script. Don't know if it would work, but worth a try. EDIT: while I don't have ILLUSTRATOR, i can export from COREL PAINT X as an illustrator file and the script works. Just tried it. This opens up some interesting options for me :)
jonbo
Post by jonbo »
Another thought. If we're talking about vector shapes, you can use cut or copy and paste the selection to another layers.
the problem is probably the complexity of illustrator shapes and sheer number of shapes/fills and points. In some ways its easier to just flatten the layers you want to high res raster parts in illustrator - breakapart script will probably justt give you a zillion unusable shapes across lots of layers...
the easiest way if you insist on importing illustrator is to split them up IN illustrator where you have best control of the shapes as they are at that point. once you bring it into AS and have to split them with millions of points your life is instantly complicated.
jonbo
Post by jonbo »
That true Funk, I only tried a few simple tests and you really get too many shapes out of it.
