Popup Book Effect
- Shanty Baba
Popup Book Effect
I am trying to do a popup book effect...rotating a background image layer in the X axis from -90 to 0. What I want at the end are the decreasing oscillations around the 0 position as it gently comes to rest.
I have tried to relicate this using keyframes and the result is passable, but can I use either bone dynamics or layer physics to achieve a quicker and better looking result.
Cheers,
Shanty
Cheers,
Shanty
- Víctor Paredes
I think the best way to do that gently movement is by hand using the graph mode.
If you are in AS8, you can check this example
http://dl.dropbox.com/u/54411/AS8/popup.anme
If you haven't AS8, you can check the graph in this image
the values I choose are pretty arbitrary, so don't think it's based on a law or something. Just be sure the wave be decreasing until get zero.
- Víctor Paredes
Oh, crossed post
- Víctor Paredes
It's ok. I'm too slow to answer and two replies are better than one. Even more when they complement each otherjonbo wrote:sorry selgin, i hate when that happens. i just finished playing some more with the motion graph so it was still fresh in my mind
- Shanty Baba
Well, I do stuff like that by hand (without any motion graphs), and it looks quite the same. As a rule of thumb: any movement in the range of just some frames is not worth to open any curve editor for.
Pop-up book effect: don't forget to set the origin point correctly as the layers will be rotated around it.
- Shanty Baba
Slowtiger,
Point of origin for rotation. You are right. That was my first mistake.
For me, Jonbo and Selgin's help with the motion graph was great as a novice. But I appreaciate what you say. "The eye of the expert" is what I call it.
I know from previous posts that you are are fan of Victorian woodcut/ cutouts, and althought I didn't post at the time, thank you for your input, thoughts and bringing that type of animation to the attention of the forum and me in particular.
Cheers,
Shanty
Cheers,
Shanty
*bows* No need to thank me for that, I'm just boasting my work like any other boy around ...
I just remembered that I did a test for "folding" images: viewtopic.php?t=13094 with the video here http://www.slowtiger.de/examples/fold.html.
