Perspective problems?
kellz5460
Post by kellz5460 »
Ok...I've made drawing and it's at a certain angle...
the problem is I want to a camera pan up but everytime I do It messes up the drawing layer and it ends up looking exploded out
basically ive made something similar to this user interface
and when I move the camera to pan up basically it looks like the drawing comes apart
is there anyway to get around this?
OMG make it stop!
jonbo
Post by jonbo »
Is there a reason you want to pan the camera up? Couldn't you just move the layer up instead using the layer translate tool?Moving the layer will keep the workspace facing the camera.
kellz5460
Post by kellz5460 »
i did try that and it ended up doing the same thing- It pushed the drawing out of sync so it looked like the layers exploded or either moved out of where they were supposed to be
i also tried regrouping all the layers but that didnt work either
OMG make it stop!
jonbo
Post by jonbo »
When you created the layers , did you make any changes in the z-axis? I've seen similar problems before when shapes were place on a z-axis other than 0
yeah the layers must be distributed on the Z axis - its the only explanation... bring them all to 0, then you'll probably have to scale and move them to get back to the look you had in the beginning...
kellz5460
Post by kellz5460 »
thx alot
OMG make it stop!
