Fade in-out transparency of an image?
Hey I'm wondering if its posible to do a Fade in-out transparency of an image? Animate a transparency?
- funksmaname
- Víctor Paredes
Go to the image layer proprieties, check "allow animated layer effects" and press ok. Then go to the frame you want, open the proprieties again and instert 0 (zero) on Opacity. Click ok and you will have two keyframes, one in frame cero representing 100% of opacity and another representing the 0%. Render it to check the fade is working.xontm00 wrote:Thanks! What if its a png file not an anime studio vector?
Thanks for your answer.
