animating group layer opacity
Am I having a brain fart? i can't work out a way to animate layer opacity (so all contents go from 0-100% without doing this to individual shape fills?! Surely this must be possible? I'm battling a deadline so a quick response is appreciated! :P
Works the same way as in any other layer:
- layer tab
- check "allow animated layer effects"
- set opacity to something not 100%
- go to other key
- set opacity to 100%
Shows up in render only, not in preview.
jonbo
Post by jonbo »
how about you use the fade script on a group layer?
patricia3d
Post by patricia3d »
I have noticed that When You render as JPG/PNG/ then Group Opacity reflects child layers, but if you export as SWF then Group Opacity not affecting child layers, but if you mark obacity for each layer then it works.
Thanks Tiger - I really WAS having a brain fart - didn't tick the 'allow animated layer effects' box!!
Thanks to the rest of you for trying as well ;)
JCook
Post by JCook »
I use visibility effects all the time. I'd really love it if 'allow animated layer effects' was the default and you didnt' have to check it all the time. It's just an extra step that I have to keep remembering to do.
Jack
