Several lines of the shapes should be invisible.
They do not appear in edit mode, but they do, when I export as AVI or QT.
When I export as SWF, lines do not appear (so, it works).
What could this be?
Hidden lines appear in AVI and QT, but work for SWF
If this is the problem Mike's referring to, then you can check out my bug report and solution to the problem.
viewtopic.php?t=12853
