Hidden lines appear in AVI and QT, but work for SWF
ruibjr
Post by ruibjr »
Several lines of the shapes should be invisible.
They do not appear in edit mode, but they do, when I export as AVI or QT.
When I export as SWF, lines do not appear (so, it works).
What could this be?
mkelley
Post by mkelley »
There is definitely a shape order problem, when you have compound shapes that should have hidden edges -- you might try a forum search here to see the problem and solution.
If this is the problem Mike's referring to, then you can check out my bug report and solution to the problem.
viewtopic.php?t=12853
ruibjr
Post by ruibjr »
Thanks, guys.
I am going to try to redo my character.
Cheers.
