Moderators: Víctor Paredes , Belgarath , slowtiger
fery_Y
Posts: 28 Joined: Tue Sep 09, 2008 12:37 am
Post
by fery_Y » Tue Sep 16, 2008 3:38 am
how move sounds place 1 to place 2 in time line ? if Misapprehension
click here
Posts: 6324 Joined: Thu Feb 16, 2006 9:53 am
Post
by slowtiger » Tue Sep 16, 2008 4:24 am
You can't move sounds in AS. If you need to start the sound later in the timeline, you have to add silence in front of the sound in your audio editing program.
fery_Y
Post
by fery_Y » Tue Sep 16, 2008 6:17 am
THX
--> NOW HOW I CAN DELETE SOUND FROM MY WORK
Post
by slowtiger » Tue Sep 16, 2008 6:38 am
Just load a new sound, it will replace the old one automatically.
Posts: 3483 Joined: Tue Oct 17, 2006 7:27 am
Post
by Genete » Tue Sep 16, 2008 7:18 am
fery_Y wrote: THX
Better use the command "Menu>Animation>Remove Sountrack". That's the correct way if you don't want any sound in your animation.
fery_Y
Post
by fery_Y » Tue Sep 16, 2008 12:09 pm
I give you Characteristic
thx
gracias
fery_Y on Tue Sep 16, 2008 12:27 pm, edited 1 time in total.
fery_Y
Post
by fery_Y » Tue Sep 16, 2008 12:20 pm
slowtiger wrote: Just load a new sound, it will replace the old one automatically.
danke
fery_Y
Post
by fery_Y » Tue Jan 27, 2009 4:52 am
hi how i do - continue blue line to after frame -
means =
Post
by slowtiger » Tue Jan 27, 2009 5:00 am
alt-click and drag
Posts: 5854 Joined: Tue Jan 25, 2005 3:18 pm
Post
by Víctor Paredes » Tue Jan 27, 2009 5:21 am
you can go to project settings and set 0 -zero- as final frame. the length of your animation now will depend of the last keyframe you add. It's variable now.
Posts: 3174 Joined: Tue May 29, 2007 3:31 am
Post
by funksmaname » Tue Jan 27, 2009 8:12 am
omg TOP TIP selgin!
i usually alt+right click on the frame i want to end on...
Post
by Víctor Paredes » Tue Jan 27, 2009 4:43 pm
funksmaname wrote: omg TOP TIP selgin!
I usually write this tip in the forum because it seems to be it's not very famous, even when it's a great option.
