Question !! move in timeline ??
fery_Y
Post by fery_Y »
:?: how move sounds place 1 to place 2 in time line ? if Misapprehension click here
You can't move sounds in AS. If you need to start the sound later in the timeline, you have to add silence in front of the sound in your audio editing program.
fery_Y
Post by fery_Y »
THX :oops: --> NOW HOW I CAN DELETE SOUND FROM MY WORK :wink: ?
Just load a new sound, it will replace the old one automatically.
fery_Y wrote:THX :oops: --> NOW HOW I CAN DELETE SOUND FROM MY WORK :wink: ?
Better use the command "Menu>Animation>Remove Sountrack". That's the correct way if you don't want any sound in your animation.
fery_Y
Post by fery_Y »
I give you Characteristic :lol:
thx
gracias
fery_Y
Post by fery_Y »
slowtiger wrote:Just load a new sound, it will replace the old one automatically.
danke
fery_Y
Post by fery_Y »
hi how i do - continue blue line to after frame -
means =
alt-click and drag
you can go to project settings and set 0 -zero- as final frame. the length of your animation now will depend of the last keyframe you add. It's variable now.
omg TOP TIP selgin! :)
i usually alt+right click on the frame i want to end on...
funksmaname wrote:omg TOP TIP selgin! :)
:D I usually write this tip in the forum because it seems to be it's not very famous, even when it's a great option.
