Well with all the recent ideas about joints that maintain volume, I just couldn't help but contribute to the issue.
http://www.mediafire.com/?gdfizvytz1m
This solution is all about shapes instead of bones. It doesn't 'flex' as much, but it does enough to not look 'cutout'.
(Oh and while I'm at it, I used meshinstance. I didn't need to, but this illustrates why I need to modify fa_meshinstance to recognize some sort of unique names for multiple instances of the same layer. Mike?....Vern?... I know this mainly has only cosmetic/efficiency purposes for the file, but I think it would speed up any point adjustments as well. Fewer layer changes.)
A shape solution to joints
I love it!
Cool solution.
I looked at the meshinstance code... MAN! Fazek is one heck of a programmer. I am going to have to study the code more to figure out what he's doing here. Not as easy as I thought to change it. The whole thing is based on the instance layer having the same "name" as the master. It's not as easy as changing the ".dup" extension. I would have to rework the whole thing.
Each layer has it's own variable for all of its own info, like point count, layer name etc. Then there is a global variable with the "name" of the layer being duplicated. That is where it gets tricky. That global variable in your example would be "arm". It compares that to the name of the instance layer (minus the .dup extension) to determine if it copies the master layers points motion. I need to figure out a way to use ONLY the extension to determine the copying. I can either try to "tag" this on to his code or rewrite it from scratch.
Have to put this on a back burner for now. Fazek is way ahead of me when it comes to lua programming. He does stuff I find hard to wrap my head around. I get inspired by him though.
Cool solution.
Well...
It wasn't as hard as I thought:
http://www.lowrestv.com/anime_studio/sc ... stance.zip
It isn't "cleaned up". I left all the commented code and "experiments" in there. This was a fast edit. This was the easiest way to modify it. I could modify it more so just the name of the master layer is needed. For now this does the job.
Instructions
Name the instance layers anything you want BUT you need both the source name and dup at the end. Like this:
Source layer name: arm
Instance layer names:
my new arm.arm.dup
anythingyouwant.arm.dup
another layer.arm.dup
what the heck.arm.dup
eatMyShorts.arm.dup
Instructions
my new arm.arm.dup
eatMyShorts.arm.dup
slice11217
Re: Free WoW Power Leveling
Just a guess but I think that last post was SPAM, no?lwb0801y wrote:Free WoW Power Leveling: Stay Away From Scam Sites
If you've ever done a search for power leveling on Google or Yahoo, you know how expensive these services can cost you. Who wants to pay three or four hundred dollars just so somebody else gets to play the game for you? It seems insane, but people actually fall for these services, many of which turn out to be scams anyway. You should never give away your account information to anybody, and even Blizzard will never ask your for that information. However, leveling up your character as quickly as possible does have a lot of allure. With free WoW power leveling, you can get all the benefits of power leveling without paying a single cent.
Don't Pay Somebody Else
Where is the logic in paying somebody else to play the game for you? It simply doesn't make any sense, and you're missing out on at least half of what World of WarCraft has to offer you. However, you don't need to take your time if you don't want to. Free WoW Power Leveling lets you quickly progress through 70 levels without breaking a sweat. There are some guides for free online, although you can alternatively choose to pay a small fee (about $30 or so) for some of the more comprehensive guides out there. 100% free WoW power leveling is all about choices though, and you're given a whole bunch to get to level 70 with.
First, you can choose between grinding and questing. The latter is probably more entertaining to a lot of folks, but it can present some difficulties at times for casual players. Firstly, some quests require groups to complete, but free WoW power leveling will help you choose the quests which are easy for solo players to complete on their own. Some might reasonably argue that the whole reason of playing an MMO is to play with other folks, but sometimes it's just easier to do things on your own. By being able to complete solo quests, you'll become a stronger player overall because you won't have to rely on others to keep your alive and help you complete objectives.
Of course, you could always turn to grinding for your free WoW power leveling needs. Grinding is a little less entertaining because it refers to monotonous killing of monsters over and over to rack up those experience points. Still, you can set the pace at which you want to earn experience with this method, and if one monster is too powerful for you, you can always just move onto another area. Both questing and grinding will help you level up more quickly than you would by figuring things out on your own, and free WoW power leveling means you won't have to pay anything to level up.
Welcome to our wow power leveling site:
The wow power leveling exchange of experience,wow powerleveling,cheap world of warcraft gold,world of warcraft powerleveling,cheap wow gold for sale.LWB
- Víctor Paredes
Selgin,
I made a version of meshinstance with a more flexible naming convention. You can check it out here:viewtopic.php?t=12024
