It's Time for a scene change!
Yin and Yang
Post by Yin and Yang »
Okay, so I want to change the scene. So I created a duplicate of my characters, but from a different angle. I tried to hide the original versions of my characters during the time that the other clone characters are doing their things. But if I make the original characters invisible they are invisible throughout the whole thing. So how do I accomplish this task?
Demon among Angels
Yin and Yang
Acochran_89
Post by Acochran_89 »
Well I'm not sure I completely follow what you're saying, but I'll take a stab at it anyways. From my experience, I've learned that it's much easier and saves from having a messy project if you create each scene in a new project file. This really helps keep things from getting confusing and such. Even Grey Kid does this, and they are probably the best AS users out there. Just my two cents of advise. However, for an actual solution to your problem you'd have to explain it better for me to help, or wait for one of the big guys to read it and hope they reply. :wink:
I'm guessing you are using the eyeball icons in the layers palette to hide things. Like you said, that hides things for the whole timeline. That is completely different from the layer's visibility setting. The visibility setting can be changed over time.
Yin and Yang
okay, so I can change the visibility settings at one point in time on the timeline. But how?
Oh, and I would make the two scenes in different project files but I do not own any program to combine them like adobe flashplayer.
Demon among Angels
Yin and Yang
arfa
Post by arfa »
are you setting the original character layers as 'NOT visible'?
either double click the layer and uncheck the 'Visible' box or click the layers button '...' and do likewise.
This visibility is animatable so you switch layers on and off at any time during a scene
> arfa
What Arfa said...
Plus you can create separate files for each scene and either import them in for the final render (Import>Anime Studio Object), or you could render out each scene and import them back in as movies for the final render.
:wink:
phastraq
Post by phastraq »
I find that reimporting movies renders lower quality in my experience.
Another alternative is to treat each scene as a camera view. Just create a switch layer for the amount of camera views you need for your project and place each scene in a different group in the switch layer. That way when you switch camera views only the files that are visible in that view will render. No manual visibility keyframing.
Acochran_89
I've never thought of doing that before
phastraq
Post by phastraq »
I had to do a scene for a movie I'm working on from 2 different camera angles. everything from the characters to the background and props had to change for the different camera view but the audio remained the same. I just used that method to switch the camera when neccessary.
Clarence Norty
Re: It's Time for a scene change!
Post by Clarence Norty »
Yin and Yang wrote:Okay, so I want to change the scene. So I created a duplicate of my characters, but from a different angle. I tried to hide the original versions of my characters during the time that the other clone characters are doing their things. But if I make the original characters invisible they are invisible throughout the whole thing. So how do I accomplish this task?
From what i understand you are cloning all the parts to use in a different scene...
Step one
Make sure you fully rewind in the project
start copying and 1 by 1 and move to desired location (click animation - clear animation from layer - this only clears from your copy)
You need to now set the starting point (the little cross next to translate)
make sure you set these to there new location
NOw you should have a fresh copy of the 1st your new scene...just use a camera cut to the desired part on your screen
