Moderators: Víctor Paredes , Belgarath , slowtiger
DK
Posts: 2897 Joined: Sun Aug 08, 2004 10:06 pm
Post
by DK » Sun Mar 30, 2008 11:03 pm
To get rounded line caps with the Sketchy Line feature.
1.Create a line around 8-10 linewidth is ideal.
2.Click on the Sketchy effect.
3. Set Radius to 8.
http://www.wienertoonz.com/linecaps.anme
Note: This feature only displays when rendered.
Same settings, this time used on a straight line with the Line Width Tool on one end.
Cheers
D.K
DK on Mon Mar 31, 2008 4:45 am, edited 4 times in total.
DK
Post
by DK » Sun Mar 30, 2008 11:30 pm
The Sketchy Line feature in AS exports perfectly into Flash.
D.K
DK on Mon Mar 31, 2008 12:49 am, edited 1 time in total.
rylleman
Posts: 750 Joined: Tue Feb 15, 2005 8:22 am
Post
by rylleman » Mon Mar 31, 2008 12:11 am
Great feature!
Is rounded ends all the effect does?, if so I think "sketchy" is a bit misleading and not explaining what the effect does.
DK
Post
by DK » Mon Mar 31, 2008 12:20 am
As far as I could tell that's about it. I took me a while to figure out what Sketchy meant too but I'm so happy with the rounded line caps I'm not going to complain
D.K
Posts: 7043 Joined: Thu Sep 01, 2005 8:49 pm
Post
by heyvern » Mon Mar 31, 2008 12:31 am
Good grief!
Was this always there or is it new?
Can't believe with all my experimentation I never came across that one!
Fantastic!
DK
Post
by DK » Mon Mar 31, 2008 12:40 am
Well....you know what....I think it may have been there now I think of it. The only reason I looked was because I've been going through the interface looking for new things added since 5.5. Surely it could'nt have been there all along could it?
D.K
DK
Post
by DK » Mon Mar 31, 2008 12:52 am
HOLY GUACAMOLE!!! Sketchy line feature has been there all along. Just re-installed 5.5 to check!!!
Oh well......just goes to show. AS is full of suprises.
LOL
D.K
donnie
Posts: 111 Joined: Mon Oct 16, 2006 3:53 pm
Post
by donnie » Mon Mar 31, 2008 2:24 am
Wow, thanks DK!
..and it exports to Flash without any complications? (it doesn't make the file sizes bigger or anything?) - Thats great!, thanks again for posting.
DK
Post
by DK » Mon Mar 31, 2008 2:43 am
I exported a very simple object using the Sketchy line feature and it seemed to import into flash perfectly. The rounded caps are one aspect of Flash that I really love in my linework and that has forced me to work in Flash for certain projects in the past which is a pain for complex character animation. Now I can do it all in AS once again
Cheers
D.K
Posts: 10354 Joined: Mon Jan 14, 2008 2:20 pm
Post
by synthsin75 » Mon Mar 31, 2008 4:30 am
Jeez, this is why we need a comprehensive manual for ASP. Think of all the headaches a simple definition of the sketchy effect could have saved.
Thanks DK!!!!!
mkelley
Posts: 1647 Joined: Fri Nov 02, 2007 9:29 am
Post
by mkelley » Mon Mar 31, 2008 5:13 am
Anyone want to bet this ain't in the "official" AS guide? <bg>
DK
Post
by DK » Mon Mar 31, 2008 5:18 am
Hehehe....
D.K
Posts: 5832 Joined: Tue Jan 25, 2005 3:18 pm
Post
by Víctor Paredes » Mon Mar 31, 2008 5:48 am
oh, excellent tip. thank you!
Rhoel
Posts: 844 Joined: Thu Feb 24, 2005 11:09 pm
Post
by Rhoel » Mon Mar 31, 2008 6:48 am
Thanks DK, always wondered what this did. Discovered the maximum setting is 8. The line does go a little soft at this settings, which can be both desirable or a problem, depending on what you are doing.
I'm going back to a problem character with discontinuous lines to see if this is better than the brush solution.
Thanks again.
Rhoel
human
Posts: 688 Joined: Tue Jan 02, 2007 10:53 am
Post
by human » Mon Mar 31, 2008 7:36 am
Many years ago, when I was doing technical writing, we used to produce "task-oriented" documentation based on the premise
"if you want to do X" then choose "tool or method Y"
I can imagine someone doing a lengthy table of these hints, and there would be a place in it for this technique.
